996 Turbo Forum 1999-2005
Coolant Pipes finally Welded!
Old 03-08-2017, 08:52 PM
Mtrboatvr6
Mtrboatvr6's Avatar
Default Coolant Pipes finally Welded!
Just wanted to share some pictures of having my coolant lines welded. Well thats at least where it started. I ended up saying "while we are in there " more than I would have liked, however everything is now in excellent shape the way I wanted! I basically had every piece of rubber, O-ring, and tubing replaced we could find. New front radiators (all 3), GT3 RS 4.0 clutch and LWFW from UMW, GT2 slave conversion from BBI (which is spectacular btw), GT2 clutch assist spring, Coils, plugs, water pump, temp sensors, 997 trans mount, RMS, brake flush, trans flush, coolant flush (obviously). Kevin from UMW has my tune on the way, and has provided excellent insight to the project. Jeff Brubaker from Kraftwerks Performance deserves a huge thank you for getting the car ready to go. His attention to detail is second to none.
As for the GT2 conversion. I think its pretty much perfect. The engagement is so much better its almost hard to believe its the same car... Yes it is stiff, but not unbearable in the least. Definately should be paired with the GT2 assist spring like mine has on the clutch pedal. This mod is well worth the money I paid for the BBI slave to be able to reverse it to hydraulic assist if someone else ever wanted to (I sure as hell will not).
Saturday I am installing leather Recaro Pole Positions, 6 point harnesses and a GMG World Challenge roll bar
I will post pics of those this weekend hopefully.
Enjoy!
Old 03-08-2017, 09:36 PM
Drinaldis
Drinaldis's Avatar
Could you PLEASE publish a list of part numbers for all the bits (rubber, etc) you replaced ??? Please???
Old 03-08-2017, 09:39 PM
Mtrboatvr6
Mtrboatvr6's Avatar
Yep, I will pull them from the invoice when I get a sec. Most likely this weekend.
Old 03-08-2017, 09:58 PM
Kevinmacd
Kevinmacd's Avatar
Since you have the engine out, may I suggest you replace the coolant tank! Its easiest to do now.
Is your replacement water pump the metal impeller variety or the Porsche composite?
Old 03-08-2017, 10:02 PM
"02996ttx50
"02996ttx50's Avatar
sounds like a serious spring refresh lol. wise choice on the bbi part.
Old 03-08-2017, 10:39 PM
Mtrboatvr6
Mtrboatvr6's Avatar
Expansion tank was recently replaced and like new, so good there. This was the water pump used 996 106 011 77.
Old 03-08-2017, 10:41 PM
Mtrboatvr6
Mtrboatvr6's Avatar
Had to be done sometime if I ever wanted to DE the car. Figured now is as good a time as any. I like the BBI part a lot so far, hopefully it stays that way for years to come. Bonus was the weather was half way decent, so I wasnt driving in a foot of snow.
Old 03-09-2017, 08:46 AM
jpflip
jpflip's Avatar
May be this thread can help you also : (page 3 for rubber hoses...):
http://www.6speedonline.com/forums/9...-needed-3.html
Old 03-09-2017, 08:50 AM
jpflip
jpflip's Avatar
Wow impressive list of modifications plus Kevin tune!!! You will be impress I'm sure...
Old 03-09-2017, 09:02 AM
Mtrboatvr6
Mtrboatvr6's Avatar
I alread am, and Kevins tune hasnt even arrived yet!
Old 03-09-2017, 10:45 AM
ReidN
ReidN's Avatar
Beautiful!!!
Old 03-09-2017, 12:45 PM
bugeyemilo
bugeyemilo's Avatar
Nice work sir!
Old 03-09-2017, 07:25 PM
TheDeckMan
TheDeckMan's Avatar
Great work!
Old 03-11-2017, 12:18 AM
o7silverturbo
o7silverturbo's Avatar
Very nice....I just pick up the BBI slave for my car. Has not come in yet but ready to install. I like how it re-flows the power steering fluid back instead of taking apart the pump and plugging the lines
Old 03-11-2017, 01:30 AM
ducnine
ducnine's Avatar
Congrats. Looking forward to meeting up soon and check out the mods.
Quick Reply: Coolant Pipes finally Welded!
