Deciphering Date Code on Porsche Drive Belt
5th Gear
This is an oddball request, but I'm hoping someone on here can help. I've searched high and low on how to decipher the date coding on a Porsche OEM drive belt (from my 996TT) but can't seem to find anything other than timing belt coding.
Here is the belt in question:
[/url]
[/url]
What I can make out is "7C" a "0" above a "7" in the white square and a large "3". Any clue?
[/url]
5th Gear
Long story short, I'm trying to figure out if a shop that I paid to replace the belt 3 years (11,000) ago did, indeed, replace it.
I did change the belt, and even messed around making a video doing it!
There is no way a belt should fail in 11k miles unless it was damaged by external forces. My guess is the shop screwed you. Sorry.
Exactly. That is not a failure due to age -- generally the belt loses long sections of the V's -- but of contact with an accessory drive pulley. Likely there is a pulley with a very worn side too that probably needs to be replaced. And the reason for the mistracking found and addressed. My experience with my Boxster has been a water pump with bearing/shaft play accounted for the a belt's edge developing a sharp edge.
Answer from Optibelt:
Dear Frank,
the belt was manufactured in week 3 in July 2012. It seems that the belt ran over the flanges of the pulleys probably caused by some tension problems or a foreign object which comes through the belt and the pulleys.
Kind regards
Thorsten Eilers
Head of Sales Automotive OEM
Phone: +49 5271 62 - 301 | Mobile: +49 172 8673775
-----Ursprüngliche Nachricht-----
Von: Frank Baker [mailto:FKMCBAKER@OPTONLINE.NET]
Gesendet: Montag, 13. März 2017 18:41
An: Eilers, Thorsten
Betreff: RE: Serpentine belt
Thorsten Eilers,
Is it one of these?
Frank Baker
-----Original Message-----
From: Eilers, Thorsten [mailto:t.eilers@optibelt.com]
Sent: Monday, March 13, 2017 10:50 AM
To: fkmcbaker@optimum.net
Subject: AW: Serpentine belt
Good afternoon,
please let me have a photo of the date code.
Kind regards
Thorsten Eilers
Phone: +49 5271 62 - 301 | Mobile: +49 172 8673775 | Fax: +49 5271 976200
e-mail: t.eilers@optibelt.com| www.optibelt.com
An Arntz Optibelt Group company
Optibelt GmbH| Corveyer Allee 15 | 37671 Höxter | Germany Registered office Höxter, Amtsgericht Paderborn HRB 6961 Managing Directors: Reinhold Mühlbeyer, Konrad Ummen Value added tax identification number: DE 812 518
948
________________________________________________________________________ _
Our International Conditions of Sale - already known to you - apply exclusively. They are also available on our homepage www.optibelt.com/agb.
Conflicting or differing terms of business of the customer do not bind us, even if we do not explicitly object to them or even if we unconditionally render performance or accept the customer's performance irrespective of the customer's conflicting or differing terms of business.
Confidentiality note
This E-Mail contains confidential and/or legally protected information. If you are not the correct addressee or have received this E-Mail erroneously, please inform the sender immediately and delete this mail. The copying as well as the transmitting of this E-Mail is not permitted.
Von: Arntz Optibelt Gruppe - Information
Gesendet: Montag, 13. März 2017 15:34
Betreff: WG: Serpentine belt
Mit freundlichen Grüßen
Information
Telefon: +49 5271 62 -1 | Fax: +49 5271 976200
E-Mail: info@optibelt.com | www.optibelt.com Ein Unternehmen der Arntz Optibelt Gruppe Arntz Beteiligungs GmbH & Co. KG | Corveyer Allee 15 | 37671 Höxter | Deutschland
Kommanditgesellschaft: Sitz Höxter, Amtsgericht Paderborn HRA 4433 Persönlich haftende Gesellschafterin: Arntz GmbH - Sitz Höxter, Amtsgericht Paderborn HRB 6872
Geschäftsführung: Reinhold Mühlbeyer, Konrad Ummen
UST-Id.-Nr.: DE 125 450 264
Vertraulichkeitshinweis / Confidentiality note Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das Kopieren sowie die Weitergabe dieser E-Mail ist nicht gestattet.
Von: OC Info Messagebox
Gesendet: Montag, 13. März 2017 15:18
An: Arntz Optibelt Gruppe - Information <Info@optibelt.com>
Betreff: FW: Serpentine belt
Please fwd or respond if this is OEM coded.
Sent: Friday, March 10, 2017 5:04 PM
To: OC Info Messagebox <info@optibelt-usa.com>
Subject: Serpentine belt
Folks,
I am trying to determine the date code of the belt on Porsche. 6pk2285lb?
Can you help me?
Thank you,
Frank Baker
Dear Frank,
Kind regards
Thorsten Eilers
Thorsten Eilers,
Is it one of these?
Frank Baker
Good afternoon,
Kind regards
Thorsten Eilers
948
Information
Folks,
Can you help me?
Thank you,
Frank Baker
