Opionions about the IPD intake plenums
#31
I am always very careful about my mods and spending money. This car is my street car, and as I had said very stock. Not like the 3 race cars we have that I mod on a weekly basis.
Ed
#32
Sambo, No offense intended, but you are debating the value of the iPD plenum and the OP in his first post asks if the IPD plenum is worth it as a FIRST modification while his car is over and under boosting. I would suggest he understand what is wrong with the car...then determine what he ultimately wants from modifications and plan to do modifications that fir that goal. Throwing the IPD plenum as a first mod when his car currently has unknown problems is a bad idea IMHO.
Because I am looking to offer the product in my store, I would like to have first hand knowledge so that I can offer my own experiences and have and be able to talk about what the installation is like to my customers. maybe with a tune at the same time. Plenum, tune, and stock one at a time to get the effects of each mod.
I will look into a 4 wheel dyno in my area. The dyno guys that I use (and have used on other of my products for back to back comparisons) are only a single drum Dynojet. (Backstreet Dyno in Medina Ohio)
That adds complication because I can not work on the plenum and the boost issue at the same time then, however.
Ed
#33
Basic Sponsor
Cheers Ed, sorry for being responsive on that part and avoiding your initial inquiry. Let me know if I can help you with anything. I bet the guys would be willing to support you in any way on trying the product out for yourself. Once the car is fixed of course. For what it's worth here's a little bit more official description pertaining to your car being stock otherwise.
The IPD Plenums are a products of efficiency. The patented “Y” design splits and channels the intake air flow making it less turbulent and more laminar, increasing air velocity which in turn improves boost response, horsepower and torque. Unlike many engine upgrades, the Plenums improve performance throughout both power curves, not just up high or down low. The improve air flow efficiency delivers performance gains with both stock and highly modified Porsches, both turbo and naturally aspirated. You can visit the IPD website and see a ton of dynos and videos that support their products and claims which they fully stand behind with a 100% money back guarantee. This guarantee is there to give potential users confidence even though they might get different opinions they have nothing to lose.
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
#34
Again, if anyone is looking for my opinion...It is well worth the upgrade to do the 74mm TB with the IPD. Yes, on stock turbos.
And yes, I got mine through Sam also.
#35
Also, if you were to re-read the posts. I am not looking to correct any problem with the IPD. I actually know how to fix the overboost problem (or at least know what path I need to go down to get there) I only even mentioned the issue because I knew that I needed to be in the same general area and figured it would be a good time to do both.
Ed
Ed
#37
I have no doubt about the benefits of pendium as it is highly recommended by different reputable car modification companies
My only worry is that whether it is a very complicated job which needs a high skill standard and if installation work would easily lead to boost leak as our connecting pipes are used over 10+ years
#38
it's a "difficult" install, insofar as the clearance btw the the plenum and the top area of the installed motor can be measured in millimeters. i cant remember exactly as its been a few years but at the very least ( iirc? ) you'll want to loosen the motor mounts in an effort to get any extra fiddling room you can muster. still we needed a hammer to finally smack it into place. its a very tight fit. the good news is it isn't made of the cheap plastic that the oem plenum is so it'll handle some wrangling lol
as to boost leaks after install, they are actually LESS likely given youre messing with and removing the tb/y-pipe and vac lines during install.
you're more than likely going to FIND leaks, rather than actually create them.
#40
OK, now I get it.
#41
I know this isn't the NA forum but does the IPD plenum and a large TB add any hp or torque to the NA 996 engines? My Dad was wondering for his car and since this was such a recent topic of debate here I figured I'd ask...
#42
Do some research on the OEM power kit, X51 package, for his model/engine. That will tell you a lot.
#43
Now, it is as smooth as butta! Response is what I expect it to be, no more codes, and although it does seem to 'feel' strong, I will have to get it on a dyno to see what it makes.
I am from the school of thought that thinks a motor is a pump; the faster you can get air in, and exhaust out, the more efficient the motor will run. So far, it seems to be accurate.
#44
When I researched the "powerkit" available for this engine nothing came up as it apparently wasn't sold here in the states. The most information I found was in this thread and it wasn't overly specific or helpful:
https://rennlist.com/forums/996-foru...9-carrera.html
If you've got any tips on where to look I'd appreciate if you could point me in the right direction.
-Mike
#45
This makes sense to me as well on NA engines but obviously the turbo engines seem to not have quite the same affect considering the air is being forced into the intake versus being sucked through it under vacuum.
