Front wheel bearing
Front wheel bearing
My car was making a bad noise which was diagnosed as a bad front left wheel bearing. Is it normal for a wheel bearing to be bad on one corner only, on a 37k mile car?
Both of my front wheel bearings needed replacing at about the same mileage as what you have on your car.
Yep it is possible. Could be age, could be extra wear, could be damaged from pothole large bump, etc...
I'd do as Dock suggest and replace both for peace of mind.
Insert stereotypical "It's a Porsche, do it right" comment here.
Yes, the OEM bearings used at the time the car was built were not very good. The replacements are much sturdier.
Thanks. The shop suggested that we only do the bad one for now, so I only did that one. With my luck, no doubt that in a couple of months I'll have to do the other one too!
I'm sure it's different, but on the C2's it was more common for the passenger side to go bad and not the driver's side (same on the 986). So maybe you won't have to mess with the other side any time soon. Who knows?
Doing them both at once does not save you any labor cost so no loss doing just the one.
That is interesting, the passenger side went first on my Turbo. The original OEM units were crap.
Hard to know which side -- it was a rear wheel bearing -- and the advice I received from auto techs prior to this and what I had done in the past was to just replace both wheel bearings. And I told the shop owner to just replace both bearings. Shop owner advised me to not do this due to cost. (Around $400 at the time, back in 2004.)
After each of us road tested the car we agreed it was most likely coming from the left rear wheel bearing. He replaced the bearing and the noise was gone.
The other 3 bearings have held up just fine and that was 228K miles ago. The original bearings have 308K miles on them.
I just replaced both front wheel bearings few months ago on my 2002 with 33K miles. Driver's side had bad pitting and was super loud. I didn't have to do both sides, but since I was doing it myself, it was just few extra bucks. Car drives so much better and is much, much quieter.
