Exhaust Swap
Intercooler
I say if it's your 1st time. Take the bumper and intercoolers off. It takes very little time and you'll get to know your car a little better. I am in the process of changing out exhaust and it's been a lot of fun (but that's just me). My take is replace the plugs and coils while you are in there. If you take off bumper and intercoolers it's a 2 on a 10 scale of difficulty. Also take out the air filter. It will make getting the o2 sensors back in the clips a breeze and that only takes about 2 minutes.
My take from a person who has next to no mechanical experience but found the job relatively easy taking everything off. Who knows maybe I'll have bolts left over when done but I doubt it. It's all pretty insightful once you start tearing it apart.
I say if it's your 1st time. Take the bumper and intercoolers off. It takes very little time and you'll get to know your car a little better. I am in the process of changing out exhaust and it's been a lot of fun (but that's just me). My take is replace the plugs and coils while you are in there. If you take off bumper and intercoolers it's a 2 on a 10 scale of difficulty. Also take out the air filter. It will make getting the o2 sensors back in the clips a breeze and that only takes about 2 minutes. My take from a person who has next to no mechanical experience but found the job relatively easy taking everything off. Who knows maybe I'll have bolts left over when done but I doubt it. It's all pretty insightful once you start tearing it apart.
Originally Posted by Fnic99
Thanks for the tips. I have done some work on my 928 but haven't touched the 911 yet (just got it). I will try swapping exhausts this weekend. Hopefully I have all the screws and nuts that I need.
I have a nice and heavy duty drop cloth that I placed under the rear of the car so that I can set the bumper down onto it and I also like using lots of blue tape (just in case)!
Here you can see my assistant (mechanics chair with towel over it). Stock exhaust is all 1 piece and it's heavy. You need something to rest it on.
Great chance to change out plugs and coil packs if needed also
Done. Took me a few hours but not a bad job at all. Heat shields and everything else appear to be in great shape. Thanks for the help everyone.
