Random Battery Failure Experience - Page 2 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 01-05-2017, 07:19 PM   #16
jhbrennan
Quote:
Originally Posted by mfanatic325 View Post
Just thought I'd share the peculiar experience I had recently with my '01 996TT.
Preface:
- Purchased car a few months back
- Had been driving the car regularly (started up at least once per week for the past few months).
- Had just driven the car daily past two days, albeit in the rain, as it's been raining in this area as of late.
- Car has never given me startup trouble under my ownership
Out of nowhere, overnight, I couldn't start the car early in the morning.
I have a portable jumper unit which I attached to the battery leads, and the voltage read something like 11.6V
1) I've no idea what could've caused the battery to lose voltage overnight, to a point that it couldn't start the car
2) Not sure why even with the portable jumper turned on, and voltage clearly being bumped up to ~12.4V , the car still wouldn't turn over
In any case, I went to the local Walmart and picked up a Everstart Maxx Group H6 battery for about $120 USD: https://www.walmart.com/ip/16782658. Specc'd at 730 cold cranking amps.
All in all, swapped out the "old" battery, and car starts up right away.
However, the old battery shows it's from 2015. Very peculiar...why would a battery fail so suddenly? Should I be worried?
The correct size is the H7. While the W and H are the same on the H6, H7 and H8, the H6 is about 1.5 inches shorter than the H7 and the H8 is about 1.5 inches longer. Some use the H8 but the hold down clamp may have to be modified. The H7 is an exact fit and probably has a few more CCA. Take it back and get Way-Mart to install the H7.
jhbrennan is offline   Reply With Quote
Old 01-05-2017, 07:34 PM   #17
"02996ttx50
Super User
"02996ttx50's Avatar
^ fully agree. get an h7 or prepare to shortly.
with the unusually high parasitic drain these cars normally exhibit, the last thing you want to have as a fresh replacement is one with fewer CCA's than are factory recommended. 790. just because the lower cca battery starts the car, doesn't lend hope it will last even as long as the 790 cca h7's do. these cars are voltage hogs. simply put, the car starts one day, and won't the next.
also, if you don't have one yet? get a trickle charger. many of us use a 60$ ctek 3300.
"02996ttx50 is offline   Reply With Quote
Old 01-05-2017, 07:56 PM   #18
Carlo_Carrera
2011 Rennlist F1 Champion
Carlo_Carrera's Avatar
The CCA number has nothing to do with the battery's ability to deal with parasitic loss.
I had a DieHard H6 in my 996TT and it lasted seven years, yes, seven years. The Walmart battery this fellow bought is fine.
Carlo_Carrera is offline   Reply With Quote
Old 01-05-2017, 08:13 PM   #19
"02996ttx50
Super User
i assumed, however mistakenly(?) that if the cca's were lower on the op's choice ( 730-h6 ) than the cca's of the battery porsche factory recommends for the car, ( which is actually the same as for a boxter! ) then the battery would be "weaker" out of the box and a dubious "long term" choice. but your experience suggests otherwise..but, why would anyone opt for a lower cca recommended battery than a 986 boxter uses?!
i would imagine though that lower cca's would at least suggest if not confirm that the lower cca battery had less out of the box "on demand juice" than one with 790 cca's?. so, how wouldn't that translate into less battery power? i can't imagine. but if you're saying that cca's have nothing at all to do with the intrinsic power of the battery, and that the "CCA" designation has no bearing on a batteries "strength", one over the other? then i have learned something and appreciate that. congratulations also, on possibly the longest lasting battery in a 996 turbo.
btw. nowhere did i attempt to correlate the inherent parasitic drain with the size of, or the cold cranking amps of, any battery in question. the car's intrinsic parasitic electrical "drain" - which no one could argue against - has to do with the CAR lol. not the battery.
still, less isn't "more".
Old 01-05-2017, 08:26 PM   #20
Carlo_Carrera
Quote:
Originally Posted by "02996ttx50 View Post
i assumed, however mistakenly(?) that if the cca's were lower on the op's choice ( 730-h6 ) than the cca's of the battery porsche factory recommends for the car, which is actually the same as for a boxter! why would anyone opt for a lower cca recommended battery than a 986 boxter uses?!
still, less isn't "more" lol
Yes, the CCA has nothing to do with battery longevity or resistance to parasitic loss. The CCA number is just the amount of start power the battery can deliver at 0 degrees F. It is not a measure of the batteries all around strength.
Sometimes less can be overall stronger.
Old 01-05-2017, 08:33 PM   #21
"02996ttx50
Super User
ok, but what have i posted that suggests i believe that the size ( or CCA ) of ANY battery, impacts the battery's "resistance to parasitic loss"? i haven't.
though i do now understand that the cca has NOTHING at all to do with the battery "strength" though i am not "fully" convinced lol
Old 01-05-2017, 08:42 PM   #22
Carlo_Carrera
Your second sentence in post #17.
...with the unusually high parasitic drain these cars normally exhibit, the last thing you want to have as a fresh replacement is one with fewer CCA's than are factory recommended.
Not "strength", "all around strength". There is plenty of info on CCA via Google.
Also keep in mind Porsche likes to over build things. Other V6 cars out there work just fine with batteries with CCA numbers in the six hundred range.
Old 01-05-2017, 08:55 PM   #23
"02996ttx50
Super User
i see what you mean now. i misspoke.
but they sure didn't "overbuild" the accumulator lol.
in any event, i'm gonna stay with a 790 cca battery, notwithstanding your anecdotal experience with that h6.. 7 years, huh? legendary
Old 01-05-2017, 09:13 PM   #24
Kevinmacd
A cell can short out unexpectingly. Lot of times during the initial start they go. What happened is a cell went bad and the battery could not deliver the current! I bet your charing cables got pretty warm, a true sign of a shorted cell!
Kevinmacd is offline   Reply With Quote
Old 01-06-2017, 12:38 PM   #25
wross996tt
Super User
wross996tt's Avatar
All good points. My experience suggests every Porsche I have owned is hard on batteries and require the batteries to be at optimal levels to start the car (even though other accessories still work). Battery technology still has a long way to go...If the battery goes below a certain charge level, it is damaged forever and can't be "re-charged" to new. This can happen at the cell level. The suggestion for trickle charge is spot on. I opted for the Interstate MTP93 which has 850 CCA.
wross996tt is offline   Reply With Quote
Old 01-06-2017, 12:58 PM   #26
"02996ttx50
Super User
Quote:
this mirrors what happened to me a month or so ago. i had not been driving the car regularly, only trickle charging sporadically, and lo and behold, after a quick jaunt down the road, it wouldn't start up again. no warning at all.
this on a barely two year old interstate. once it's dead, i wouldn't have any faith at all it will ever be as good as it once was and that's the last time i conduct that experiement. dead battery gets an immediate call to AAA. but i DID just get a new ctek, just in case it too was failing lol
Old 01-08-2017, 05:31 PM   #27
Kevinmacd
I have never had good life with Interstate batteries in my previous Porsches! In fact, about a year ago I changed out an Interstate that was about 2 years old, and bought an oversized Bosch! So far so good.
Old 01-09-2017, 01:10 PM   #28
T10Chris
T10Chris's Avatar
If dont drive the car a couple of times per week definitely need a trickle charger or pull the negative cable on the battery.. leave your front lid cracked if you pull the cable, but if does get closed you can connect to the fusebox in the driver's footwell to give it power to open, or can relocate the manual release to an easier to access area.
I didn't charge mine and the car sit for 3 weeks so it didn't start when I went to move it- checked battery voltage and is 7.4 so pretty sure it won't ever be right again so plan to replace it. Bosch battery, OEM spec, 1 year old. These cars have a constant drain.. I've monitored it with multimeter connected and checking it frequently over the course of a few days.
T10Chris is offline   Reply With Quote
Old 01-09-2017, 01:16 PM   #29
mfanatic325
User
I will definitely be getting a trickle-charger, regardless.
But in any case, I just went with whatever battery was suggested via the Walmart site. If they're for whatever reason wrong, well, at least I have their 3+2-year warranty
In fact, if this battery DOES fail prematurely, I could potentially be getting more "bang" for my buck since Walmart's merchandise return policy is pretty good
mfanatic325 is offline   Reply With Quote
Old 01-09-2017, 01:56 PM   #30
T10Chris
T10Chris's Avatar
Yep, can't really beat the warranty they have in case of another failure.
I'm thinking of going another route, lightweight battery maybe even Lithium-Iron.. 5.5 lbs and allegedly cranks better than the typical lightweight Odyssey, etc; plus it is lighter. Seems like a win/win. Haven't made up my mind yet. Your idea is solid and may copy that as well to avoid hassles
Related Topics
Thread Thread Starter Forum Replies Last Post
Chasing electrical/charging problems in my '82 jheis 928 Forum 10 02-02-2017 07:12 PM
Anker Portable Battery Jump Starter - Review Hacker-Pschorr 928 Forum 2 04-16-2016 03:14 AM
Battery Failure? 3Series 997 Forum 14 08-21-2015 03:24 PM
2008 CTT Left me stranded again...second month in a row! Atlantan Porsche Cayenne Forum 1 08-16-2015 12:32 PM
Battery Gauge Question Ray S 996 Forum 7 03-31-2011 11:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2015 Rennlist.com
