New clutch - question about pedal free play
Hi Everyone,
So I got my car in August, and ever since had an issue getting into first gear.
The ppi at the dealer didn't pick it up. Eventually I had it diagnosed as requiring either a synchro or gear being worn. Just had the transmisison repaired and they fixed the issue (after repacing 1st and 2nd gear and both synchros). I had the clutch disk, pressure plate and throw-out bearing replaced all with new stock parts at the time as well as the flywheel machined flat on the advice of my mechanic.
I also replaced the accumulator a few months ago and have been keeping an eye on the front reservoir and the level has been steady with no leaking.
So my issue when I picked up the car is that the clutch pedal now engages almost right off the floor and at the top there is much more free play that I notice than before. I'd guess it's about 3/4" - 1" of travel. Shifting into first is perfect (as I would have expected).
Is this normal after putting in a brand new clutch? Is there something they missed?
Thanks in advance!
Thanks in advance!
