Battery change in an 04 996TT
I updated my battery to a larger size, Bosch, bought at pepboys, had do do minor change to the battery tray and tie down. The change was ver minor. Battery is two years old and holding up great.
Do you guys ever use an Optima battery. That's what I had in the 912 and is was fantastic.
http://www.yellowdogmotorsports.com/details.php?id=104
If you use this tray, the Optima Red Top 34R is the battery you want. The positive cable may not reach the terminal on the 34.
not a Optima fan, but use whatever you prefer...my dad's 6TT came with a bluetop, removed it and installed a proper H7
Any recent changes in replacement battery recommendations? Need to replace the old one in my TT soon.
Just replaced mine last week, went with Interstate..
Are used to use Interstate batteries but the past couple have died prematurely so now I just go with the Everstart Max from Walmart. So far so good.
If you do some research you'll find that most of the battery brands out there are actually made by Johnson Controls.
I’m on my second red top and it’s lasted almost 9 years still has some life lives on a ctek to keep it topped off. My first red top only lasted 5 years but it was on a standard charger which I’m sure was overcharged and shortened the lifespan.
