Apple connection question
Just bought my '03 996TT and it came with an old Apple connection (pic attached) to the PCM. After some research here, I thought it might be a Dennison hook up so I tried an adapter to my iPhone 6 but nothing happened on the car's end or the phone's. Anybody know how to get this to work? I tried every input. Thanks for any advice.
My guess is that the PO disconnected the CD player and has this plugged in instead - or do you have an auxiliary input choice?
On my old 99 I had that type of connector plugged into the back to listen to my iPod.
Thanks for the replies everyone. I've tried the following based on the responses but still can't get any action.
I plugged in a 30-pin ipad and a message came on the device screen saying something to the effect that it may not support this accessory. The music stopped playing on the ipad but no response on the car's end. I tried CD and CD changer, but nothing. Note, when I plugged in my wife's iphone 6 with the adapter there was no such message on the phone.
Upon further inspection, I noticed a toggle switch along the side of the panel (pic attached). Any ideas on what this is?
I pulled the cubby out to see where the wire is going. It is appears to feed below, away from the radio (see pic attached).
The radio does not have an auxiliary option. Once I find a CD lying around, I'll try it and see if it works to determine if PO disconnected it.
Thanks again for all your help!
Toggle switch. It was switched on when plugging in devices.
Cable feeds down below.
That toggle switch looks exactly like the one on my car to switch the laser jammer on and off. Judging by its location that likely what it's for. Do you have a laser jammer? Do your speakers beep when you switch it on?
No jammer, but the car is hard wired for a radar protector so I suppose it's possible it used to have one. I don't hear a beep when I switch it on.
So toggling the switch does not appear to affect anything in the car. The in-dash CD player also works. Any ideas? My next step I guess would be to try a 30 pin iphone and see if that does anything.
After some searching, it looks like this might be a Mobridge, which apparently will play the ipod through FM station 89.7. I got clear sound on 89.1 (go figure) after toggling the switch. I'll try the iphone later tonight and see if that will play.
Given the above, any more ideas what this is? I emailed Mobridge with some pics but didn't hear back.
Edit: Looks like it's an FM modulator:
https://rennlist.com/forums/996-foru...e-install.html
These threads gave me the idea to change the frequency:
https://rennlist.com/forums/996-foru...es-wanted.html
