New to rennlist
New to rennlist
Hey guys, been on 6speed for quite some time but figure I'd come over here as well.
I'm Freddy, from Fargo, ND. My car has been under construction for some time but finally should be done being tuned by the weekend of the 6th. Here is the build sheet and some pic. 95% of the work I did myself.
Engine:
Pinned coolant lines
Vac reduction, secondary air pump delete
Ipd plenum with 74mm tb
Custom fuel system, dual walbro 450 pumps, -8 an supply line, -6an return, 1300cc injectors, flex fuel sensor, fuelab fpr and filter
K20/billet 20g turbos ported
Ported manifolds
Catless 3inch x pipe exhaust
3 inch y pipe
4.5 inch srm intercoolers
Proefi 112 stand alone ecu
Torque solutions motor mounts
Gt3 dipstick conversion
Evap system delete
Filters on turbos
Transmission
Exedy triple carbon r clutch
Oem gt2 slave conversion
Wavetrac lsd
Poly bushing mounts
Shift lever counter weights removed
Suspension
H&r coilovers
Eibach adjustable sway bars
HD adjustable end links
Solid thrust arm bushings front and rear
Poly lca bushings front and rear
Poly toe link arm bushings
Lockout plates
Solid rear subframe bushings
Adjustable dog box arm with solid heim joint ends
Brakes
997 tt 350mm rotors
Spacers for stock calipers
Rpf 600 fluid
Ss lines
Body.
Side radiator bracket mod and relocate
Modded fender liners
Joe toth gt2 canards
Rolled and pulled fenders
Rennline front screen kit
Wheels
Forgestar cf10
19x9+40
255/35/19 re-11
19x12+40
325/30/19 re-11
There is more stuff I forgot I'm sure.
Engine:
Ported manifolds
3 inch y pipe
Evap system delete
Filters on turbos
Transmission
Wavetrac lsd
Poly bushing mounts
Suspension
H&r coilovers
Lockout plates
Brakes
997 tt 350mm rotors
Rpf 600 fluid
Ss lines
Body.
Wheels
Forgestar cf10
19x9+40
255/35/19 re-11
19x12+40
325/30/19 re-11
