Boost leak from driver's side intercooler... is there an easy way to get at it?
Replaced check valve 16 tonight and followed up with a boost leak check now that I can actually hold a little bit of pressure. Driver's side intercooler is leaking from the rearmost hose fitting (it seems). Is there an easier way to get to this to tighten it than removing the whole rear bumper?
Thanks.
-Mag
Thanks.
-Mag
I had a hose at that same place that didn't seat properly when I put in new 997.2 IC's and could push it back in but it would pop as soon as I stood on it again.
Replaced the hose with another one I had.
The hose flange ears wear down and it will pop under boost.
Had to pull bumper again, no big deal. Spend the hour, do it right so you can see what you're doing and put on some heavy duty zip ties over the clips while you're at it.
I did a little more digging and realized that it's not the fitting leaking at the hose... it's the dang intercooler itself. Bummer. These are aftermarket intercoolers (not sure of the brand). Now I'll be looking for some 997.2 intercoolers. Excited about that (sarcasm alert).
ETA: Just realized I can't use 997.2 intercoolers unless I get the OEM hoses to go with them... I have aftermarket silicone hoses also... so no direct swap for me. Pretty sure I'm going to take that intercooler over to a welding shop and let them have at it... or pack it full of gum and see if it holds. One of the two.
Finally got around to pulling out the intercooler last night and the leak is pretty deep inside the intercooler. Gave it to a friend of mine who does aluminum welding for jets to see if he can get at it but he's going to have to cut about 2" worth of fins out to get to it. I ordered a 997.2 intercooler to replace it just in case it gets mangled in the process. It's ok to run different intercoolers on each side, right?
I have a complete set of the latest version of OEM hoses with the new style end tabs, all 4. Only used for 4K miles, perfect condition. 1/2 price. Also have a pair of 997.2 Intercoolers. They both have a small leak near the turbo side of the end tanks. Nothing major but small bubbles do appear when pressurized and sprayed down with soap water. $250
The DME can keep the fueling of the banks the same, the timing advance of the cylinders in each bank the same and this each bank of cylinders contributes the same amount of power to the to total engine output.
In your car's case I'd forego the attempted repair of the leaking intercooler and just replace both intercoolers with either the same or improved ones either from the 997 Turbo or perhaps aftermarket.
No science to back this up just intuition but I'd say "no". You want to avoid the possibilty of supplying air charge cooled to different temperatures to the banks. Ideally each cylinder bank wants to receive intake charge of the same temperature.
As a follow up to this (kills me when people don't conclude their issues):
Installed a 997.2 intercooler today. The upgraded EVOMS intercooler had a leak inside that was unrepairable so I got ahold of a decent 997.2 intercooler to try out (thanks to the advice on here and 6speed). It was a pretty easy install since my ducts were already modified slightly to fit the evoms intercoolers in there. I did have to buy a new set of hoses since my aftermarket intercoolers didn't use the stock hoses/fittings. Otherwise it was pretty easy and the car pulls like a **** now that my bigger boost leak is taken care of. Now back up on the ramps to look for more leaks. Fun.
