996 Turbo Forum 1999-2005
Alternator Install Torque Specs
Old 04-24-2016, 01:37 PM
Ck986
Ck986's Avatar
Default Alternator Install Torque Specs
I'm a bit **** when doing these things and want to make sure everything is as tight as specified by the factory.
According to the work shop manual the bolts that hold the alternator are tightened to 34 ft lbs. They are called head bolts, but just wanted to verify with someone that has already done this as the manual is not very clear on all things.
The deflection roller or pulley under the alternator is tightened to 34 ft lbs per the alternator install instructions, but on another page in the manual it shows 17 ft lbs, which is correct?
Are there any torque specs for the y pipe screws?
Thanks for the help.
Old 04-24-2016, 03:10 PM
iotapi322
iotapi322's Avatar
I've done this exact job. I've done the pulleys at 34 ft lbs. The alternator I couldn't get the torque wrench in that tight spot so I guessed by hand.
Old 04-24-2016, 06:47 PM
Ck986
Ck986's Avatar
Well that was short lived, I couldn't get the rear screw off so Will just have the shop do it or I need to look for a longer 15mm wrench.
Old 04-25-2016, 06:33 PM
Ck986
Ck986's Avatar
Just to check the left screw unscrews clockwise as It's backwards. I bought a longer wrench that will hopefully provide more leverage.
Old 04-26-2016, 11:24 AM
z06801
z06801's Avatar
This is a picture from Renntech he's using a block and getting some leverage on the wrench worked great for me also a ratcheting closed end wrench makes it a lot quicker to get the bolt out.Attachment 1045005
http://www.renntech.org/forums/tutor...tor-pictorial/
Quick Reply: Alternator Install Torque Specs
