996 Turbo Forum 1999-2005
Falken RT615K @ Tirerack
Old 03-30-2016, 05:21 PM
993GT
993GT's Avatar
Default Falken RT615K @ Tirerack
Got exciting news today, Tirerack will now be carrying the RT615K
my favourite all-round performance tire in our 315 sizes
Old 03-30-2016, 06:18 PM
Kevinmacd
Kevinmacd's Avatar
Doesnt help me need 295-30-18
Old 03-30-2016, 07:37 PM
Road King
Road King's Avatar
For non track use I'm having great success with Falken's Azenis FK453s...they come in stock 996T sizes.
Old 03-30-2016, 07:57 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,232 Likes on 1,441 Posts
You can pair 315s with 245/40s.
Old 03-30-2016, 11:01 PM
James88
James88's Avatar
I believe this a better match for our awd than 235/40/18 & 315/30/18
Old 03-30-2016, 11:07 PM
jeanmarcboilard
jeanmarcboilard's Avatar
+1
Old 03-31-2016, 08:35 PM
split71
split71's Avatar
Dammit! Just put a set of Pirelli's on as that was the only tire I could find in matching AWD sizes stated above.
Old 03-31-2016, 11:32 PM
xmaciek82x
xmaciek82x's Avatar
Yup. Much better match then 245/40.
Are you guys running 315/30-18 on 11" wheel?
The RT615K is a mean looking tire!
Old 04-01-2016, 12:17 AM
James88
James88's Avatar
245/40/18 & 315/30/18 is a better match for awd than 235/40/18 & 315/30/18, front tire needs to be a bit taller than the rear.
Old 04-01-2016, 12:59 AM
xmaciek82x
xmaciek82x's Avatar
OK, the last debate I read on this topic was that the rear and fronts just need to be within certain % from each other, I believe it is 3%. Didn't really matter which one was smaller. The Porsche winter recommended tire size make the front smaller then rears. The summer recommended size make the rear smaller.
But having said that, when I did the calculations for 245/40/18 & 315/30/18 and 235/40/18 & 315/30/18 I completely forgot to pay attention to which one is taller. I change what I originally said and would go with the sizes that make the rears slightly smaller like the summer recommended sizes.
Old 04-01-2016, 02:09 PM
"02996ttx50
"02996ttx50's Avatar
for awd i am fairly certain the 3% differential ratio btw front to rear is correct to not cause damage to the front differential by overheating it but i've always heard said that the REAR is the tire that if at all needs to be taller. not the front. i'm rwd so i have a bit more latitude if not sizing choices, but at least i don't get those dreaded cels when matching old X new tires. 235/40/18 X 315/30 still seems optimal for me handling wise. i've never felt the need to mess with success or stray too far away from porsche's recommendations. aside from the rwd part, of course.
but now i'm confused. is everyone certain that it's the FRONT that should be taller?! i'm a bit skeptical of that somehow.
Old 04-01-2016, 02:13 PM
Road King
Road King's Avatar
Yes, front is taller from the factory on all AWD 996 Turbos
225/40/18 approx 25.1" tall
295/30/18 approx 24.9"
Hence the front turns slower / less revs per mile.
Old 04-01-2016, 03:33 PM
James88
James88's Avatar
Phound recommended 245 over 235 for awd, fronts need to be a bit taller like factory different diameter
And this is my dilemma as l can't find matching tires in my prefered PS2/ PSS
Old 04-01-2016, 03:36 PM
993GT
993GT's Avatar
both 235/40 and 245/40-18 front tires are completely safe and acceptable with a 315/30-18 rear
Old 04-01-2016, 04:17 PM
James88
James88's Avatar
Dont you think the slightly taller front biased would be a better match?
Quick Reply: Falken RT615K @ Tirerack
