How to pressure wash underneath car?
What's the best way to clean underneath the 996tt?
Car is currently in for service, and tech has recommended I get the 996tt's underside to be pressure washed to get rid of east coast salt/grime/pebbles to avoid corrosion.
Short of taking it to a detail place, I'm thinking this could be a easy thing to do at home.
Any ideas for a DIY? Take a garden hose and spray it underneath the car? Should I try taking my pressure washer and blasting the car's underside? Would the pressure washer cause any damage?
Thanks!
Thanks!
If you can get satisfactory results with garden hose then do so, otherwise pressure washer is fine(naturally, be carefully how strong/close you use it and avoid pounding it into electrical connections and such) ...all-purpose cleaner and a standard paint brush are effective.
When I bought my 928, I put it on my 4 post lift and spent a ton of time under it with a spray bottle of degreaser and a wire brush and a spray bottle of water. I put several layers of newspapers on the floor to catch the falling crap. Be sure to wear goggles and a stocking cap to guard against cleaner.
Some keyboard research suggests that Easy-Off Oven cleaner is very effective at removing grime/crap from underneath the car (in addition to the grease on the BBQ). '
I'm tempted to pick one up at Walmart, spray it underneath the car, and wash it off with water.
are you trying to remove the cosmoline or just clean the car?
The car is currently at the shop getting new mounts/water pump. Tech suggested I get the underside cleaned to remove visible East coast salt/grime/road debris. He recommends a detail at a local detail shop, but shop here wants $995 for a full detail!
Figure I try and do it myself.
are they offering a cyro/CO2-detail?
I'd just use dish soap or all-purpose cleaner and a brush and wash off
unless you are trying to remove carbon, I don't see the need for oven/wheel cleaners...except for maybe some brake area detailing...need to watch it doesn't etch the metals and paints...
Ive used brake parts cleaner for under-car clean up purposes. Get it up in the air and spray it directly on it and it evaporates off after eating up the grime/dirt/debris. I've been meaning to do it to my car, but I haven't had a chance as of yet.
Good idea! Brake parts cleaner seem more gentle on the car but volatile on the skin. CRC Brakleen Brake Parts Cleaner at NAPA seems highly rated and cost effective. I might try this or just plain dish washing detergent.
