996 Turbo Forum 1999-2005
Vacuum leak and/or stuck throttle. Needing me some help checking it out
Old 02-13-2016, 03:36 PM
RngTrtl
RngTrtl's Avatar
Default Vacuum leak and/or stuck throttle. Needing me some help checking it out
Greetings all,
After a wonderful drive back to ATL from DFW where I bought the car I got a CEL for a P-0507 (high idle) and it is usually a stuck throttle plate or a vacuum leak somewhere. The car is idling high (about 1000-1100 rpms). I cleaned the MAF with MAF cleaner just in case. I am good with a wrench but am new to this car (I had a n/a 996 for several years). I want to go out there and check all vacuum connections and remove the intake y-pipe at the throttle body and also check the turbo air hoses. I found a vacuum diagram i think.
http://goo.gl/W86YSD
Any one have any advice on this? Also I could not find a write up for removing the intake y-pipe after searching. If anyone has any pointers on this it would help alot. Thanks!!!
Old 02-13-2016, 03:46 PM
rmc1148
rmc1148's Avatar
http://www.6speedonline.com/forums/9...ody-reset.html You could try this.
Old 02-13-2016, 03:48 PM
RngTrtl
RngTrtl's Avatar
Originally Posted by rmc1148
Hmm. As simple as it is, ill go do it now and report back ina bit.
EDIT: I went through the reset procedure and heard it resetting, drove it around for a bit (motor was still 1/2 warm from previous drive), and same idle at stop. About 1000-1100.
Old 02-13-2016, 09:51 PM
James88
James88's Avatar
Had this happen to me just 2 weeks ago, I had a vacuum leak. All good now.
Old 02-13-2016, 09:59 PM
z06801
z06801's Avatar
Where was the leak found?
Old 02-13-2016, 10:00 PM
32krazy!
32krazy!'s Avatar
smoke test the vacuum system. you can use incense for this
Old 02-13-2016, 10:08 PM
James88
James88's Avatar
Vacuum hose under manifold. Had the hose replaced, It also fixed the annoying hesitation under light acceleration that I had for the past 12 months.
Old 02-14-2016, 12:40 PM
z06801
z06801's Avatar
Nice work I need to track down mine, I have the same issue.
Old 02-14-2016, 04:16 PM
RngTrtl
RngTrtl's Avatar
I will try this as well. the weather is supposed to warm up next weekend and I will try and find it then. Hopefully some others can chime in with some more advice before then.
Old 02-14-2016, 05:00 PM
32krazy!
32krazy!'s Avatar
you have to unbolt the airbox and rotate the airbox 120* to the drivers side. to remove. once its out of the way you can see the clops holding the y pipe and the bolts to remove. theres one clamp at the throttle body . lots of vacuum lines and seals around to check. after that do a full boost pressure test when it all back together. testing from the turbos yield the best results
Old 02-14-2016, 10:44 PM
rmc1148
rmc1148's Avatar
Did you try the TB reset? Just curious.
Old 02-15-2016, 12:37 PM
RngTrtl
RngTrtl's Avatar
Yup. same results
Old 02-15-2016, 12:38 PM
RngTrtl
RngTrtl's Avatar
Thanks alot for the help. I will dig into it this weekend when it is a bit warmer and report back.
Old 02-15-2016, 12:51 PM
rmc1148
rmc1148's Avatar
Oh well it was a free and easy try, the vac leak hopefully will be easy to find.
Old 02-19-2016, 04:22 PM
RngTrtl
RngTrtl's Avatar
I found the vacuum leak! After I got all the intake off except for the throttle body. I had to do some serious hunting and found it after about an hour. The mount for the "Electric switch−over valve for secondary air" on the drivers side broke and when it let go it pulled out of the vacuum line leaving out of check valve #22. After much effort I was able to dig around and get the hard vacuum line out and I reran the line with some material from Autozone. All is well now and she idles like a champ. Now I need to drive the car for a bit and reset the evap ready and the secondary air ready so I can get her registered. Thanks to all for the help!!!
Diagram below for vacuum routing
Quick Reply: Vacuum leak and/or stuck throttle. Needing me some help checking it out
