Need expert opinions pre purchase
I found a nice 2003 silver on black with x-50 and PCCB. 89,000km for 55,000$ CDN. However I am looking at some of the previous owners documentation and found this relating to over revs:
Range 1: 64000 2254.8HR
Range 2: 689 2254.8HR
The car has some sort of GIAC programmer in the glovebox so not sure if that would account for the large Range 1 over revs. One of the inspections also reveals "brake rotors worn from track use". Now I understand you can replace the carbon rotors with steel but I would imagine this is still a fairly pricy job.
What do you guys think?
Received 5,388 Likes
How many hours on the car currently?
Range 2s are more severe, and most usually a result of a missed shift.
I have to disagree my friend.. you can take the engine to 6800 and trigger type 1 but not hit the rev limiter.
the limiter is just north of 7000.
Touching redline is not the same as hitting the REV limiter.
The limiter is the point where the ecu cuts fuel.
Banging off the limiter can take you over 7250 also as the fuel is cutting on and off.
