996 Turbo Forum 1999-2005
Need expert opinions pre purchase
Old 08-25-2015, 08:19 PM
Kevin
Kevin's Avatar
I'll bite on this one.. The STOCK 996 Turbo Fuel cut/RPM limiter is set at 6750 Period.. On the stock engine if you push the throttle pedal to 6751 you will get fuel cut.. In the factory CODE, you have the binary 6750 limit. Why would you have a non enforced limiter set at 6750, that does not give you any FEEDBACK or fuel cut at 7000RPM??? If you hit the fuel cut you will trip Type 1's at 6750..
Now, most tuners will raise the limiters and type 1 and type 2 range counters....
Old 08-26-2015, 02:17 PM
yjoseph
yjoseph's Avatar
Then I stand corrected if this is the case.
When I first had my car I was able to take it to 7000k no problem.
I believed it to be stock....
Quick Reply: Need expert opinions pre purchase
