The cool down
IMHO:
0 second for frequent centre section replacement
30 seconds for a 'down the street' drive,
2 minutes if driven enthusiastically,
5+minutes when at track
cut time in half for water-cooled turbo's
I personally just drive though my neighborhood which always seems to bring the EGT temps down to what I would see at idle. I don't take any other precautions since it seems pretty wasteful what possible gains would I get if the EGT temps are no longer dropping at least not in any significant way.
There are certainly things you could do to make your Turbos last longer but at what cost and what gains. I have spare K16 Turbochargers from many upgrades I have done in the past.
The removal of catalyst would certainly help the exhaust system remove heat after cool-down tremendously.
You could also throw blowers onto the turbos at idle and after shutdown to remove more heat.
I've always applied the "no boost" for last 5 minutes of my drive rule, to cool down oil cooled turbos. If I do go into boost in the last 5 minutes, I will let it idle for at least a minute or two after stopping. Common sense applies here. If you are hooning the **** out of the car, more cooldown time is a good idea. I've never had a problem with any oil cooled turbos simply using common sense.
Just curious for those of you that don't cool down at idle...do you have any idea what your turbos look like? Just saying you have no apparent problem is not really data to draw conclusions from. Again, I defer to the master who has actually rebuilt 100s of our turbos (aka Kevin)...Idle cool down for 60-120 seconds NO MATTER WHAT.
Driving with engine RPMs obviously above idle even though the engine is not making any boost still has the turbos hot, relatively speaking.
The cool down ensure the turbos are as "cold" as they can be before the engine is shut down.
You are still shutting off the engine with the turbos hotter than they would be had you let the engine idle the recommended amount of time.
Slightly hotter, sure, but nowhere near hot enough to do any damage. I've never had any issues with turbos doing what I do. Turbos get REALLY hot in boost, and cool down quickly out of boost. A turbo that has been exposed to steady state operation under 3000rpm and out of boost for 5 minutes will be very cool relative to a turbo that has just completed a 1/4 mile run.
I used to shoot the turbo on my S60R with my infrared heat gun after driving it out of boost and after idling. The temperature difference was within 100F, which is a tiny difference on a turbo.
