What to worry about with a modified 996TT?
#31
#32
now what dummy?
#34
The car I'm looking at has 37580 type 1 over revs and 1956 type 2. The rev limiter on the car is 7300 rpm with tune. Owner says he's never missed a downshift but hits the rev limiter regularly. The range 2 could be from hitting the rev limiter in up shifts? Car puts out around 625hp.
And be nice guys.
And be nice guys.
#35
i didn't begin this ad hoc ad hominem attack. some a**holes just lie in wait, AND SUDDENLY MAKE THEIR MOVE as if there is something to be gained. ain't no one talking to quadscammer.
#36
And be nice guys.
And be nice guys.
sorry about your thread lol.
#37
With the typical flash and exhaust, nothing to worry about except the driver, though refreshing DVs, plugs, coils and MAF gives extra peace of mind. With some aftermarket turbos (fast spooling, high flow, so high low down torque) it depends on the tuner as rods won't bend at the high rev power peak (where much of the power is being made from the high frequency of ignition cycles), they usually bend before the engine's torque peak as that is where the most work is being done per ignition cycle. Some (most?) tuners will cap low down torque where this would otherwise be a risk.
If you're thinking to use a highly modded car's performance on any street course, then supporting brake and suspension mods would be a good idea too I'd think.
#38
i dont have one but was last was dyno'd by the guys at speed gallery when the 1.2 tune and 16/24's were added where the car was serviced ( and still is for "major" non driveway work ) so it's a guesstimate but am told I'm safely btw 575 and 600whp ( but 600 maybe/probably when I've had a cpl beers )
i dont have any fuel beyond using the 5 bar. but interestingly, there's a recent thread on 6 from 996tt550hp and i think he just got 564awhp? and i'm similarly modded but running rwd with maybe a cpl more parts ( plenum? ) and 24's hotside.
i'm thinking of actually going to this new place in torrance that can dyno and the rollers are setup for rwd testing. i'm curious to see hard data also! though my parts combo has been tested a lot since its so "common".
http://www.6speedonline.com/forums/a...much-more.html
One other guy in my area has K16/24s with 5 bar, intake pipes and Europipe exhaust. He also did in the low 500s on 91 octane.
#39
Gotcha. Yeah, go throw it on a dyno and get some numbers. I'd be curious how it stacks up to the K16s I have. I know of several people, namely Mike Kelly that used to frequent these forums and he had the same K16/24 you have, 5bar, diverters, exhaust, etc. etc., and his car was low 500rwhp, around 510 I think running 1.2 bar (not sure what gas). His set up was basically identical to yours. His car was one of the strongest K16/24 cars out there pulling the front wheels off the ground on a drags trip. Here's a link to it showing his mods.
The good news is I have no personal stake in whether or not I'm at 525 or 600 rwhp and also that scamswatter wouldn't find ANYthing not working exactly as it was designed to. HAH.
But I will dyno it again and share the results John. Thanks for asking!
#41
How do I know that there is an additional possibility that the modded car has been driven even harder than it might have been, in order for the driver-owner to enjoy those mods, or how do I know that it is "likely" that people with modified cars drive them hard (or both)?
#42
Yes
