Street & Track Pad
Street & Track Pad
Any pad that's sufficient for double duty? Factory pads were on the way out at my last tech inspection, had the shop put in Pagid Black RS14 at their recommendation. They work well at the track, but they are quite loud for the street. Or should I just get another set of pads and swap back and forth?
I have tried every high performance street/track pad there is and on a Turbo with the HP and the weight they all fall way short in the track department. The best one by far was StopTech Street Performance pads but even they left me wanting more stopping power.
Some guys like PFC 11s for both street and track but I have yet to try them.
My advice is buy a nice set of low dust, low squeal, pads for street driving and use the Pagid Blacks or Yellow RS19s at the track.
go with stock...I'm thinking about picking up a set for daily duty as well. They do everything well except dust, which I'm completely fine with.
Have run my PFC 08/11 on street/track for about a year now, the noise on street-duty is horrific(the worst I've ever heard...), just re-installed my pathetically-low fiction(almost dangerous I'd say) Stoptech pads a week or two ago so its less embarrassing on the street, but might go back to the noise of PFC's as I hate the braking power of Stoptech's....or will just order up some OEM pads and call it a day.
You can also check out Racing Brake, they have some good compounds that are good for street/track.
Stoptech S.P. brake pads are fantastic at everything but braking, lol.
Give the PFC's a shot, fantastic on track! Huge torque with excellent modulation.
I am running the pfc 08(front) and 11(rear). most of the time they are quite quiet. they stop much better than stock. and no fade while on track. be sure to bed the different pads to the rotors.
The Pagids work well at the track, plenty of braking, good modulation. Seem to have plenty of capacity for heat (track I was at isn't that hard on brakes). They feel a little gritty on application compared to stock.
The noise though on the street though, it's like I'm driving an empty 50 ton dump truck.
As far as bedding, I tried the pagid recommended bedding procedure but coudln't seem to get enough heat into them. Not enough empty roads around here. The instructions are 10 stops light pressure from 85 to 45 and then 5 stops high pressure from 110 to 35. Riiiiiight.
I am using Yellow RS19s now. Happy with them, they work.
OP, I run PFC01's on my track car and I swear they will make you feel like a much better driver than you actually are due to the sheer force they can suck from your chest. I don't remove them for street driving, but don't drive many miles on them so the squeek doesn't annoy me much. I vote stock pads + PFC11's and have the best of all worlds (except dust)....
996's are heavily front-skewed in braking bias...need all the stopping trque shift to the rear we can get...997's are better, will eventually do 997 rear calipers(larger pistons) to gain 'natural' hydraulic bias toward rear and be potentially able to run a matched pad compound. PFC 11's are very agressive
Why the rear biased setup? I would have thought a 996 was already rear biased from the weight distribution, why not PFC 11 all around?
All cars are skewed with front braking bias due to the forces acting on the car during braking (shifting weight over the front axles). I would have thought the 996's brakes are less skewed (due to the engine placement), as they implore the same rotor sizing front to back unlike my bmw track car albeit with less piston area in the rear.
I guess the tire contact area plays a large role with such huge huge differences in tire width. Have you run a more aggressive pad up front that resulted in unwanted tendencies prior to switching to the 08's? Just trying to learn as I am new to the 996tt. Thanks in advance!
MOST cars, but I know what you're getting at.
996 were probably designed in the interest of 'confidence/safety' of an average street driver, when you push them they need more rear bias...again this is driver based as well...some like same pads front/rear, stock bias....
IMHO 08/11 is near perfect combo on stock PCCB calipers/disc size to help balance...when running matched pads the fronts are easy to lock while rear still isn't doing much. So far with my GT2 I've had PCCB, Stoptech pads on steel, PFC on steel.
I'll try to take a 'steel brake' 996tt out within the week to revise my memory...
That pad combo will wear the rear rotor really quickly and the rear rotor will really need to be upgraded to something larger to take the pad abuse.
We'll have to agree to disagree
Typically, more rear bias allows the car to rotate easier and should allow greater front end transition while braking as the tire is forced to do less work, but again each driver will have a preference based on their confidence/driving style in the car/setup.
997's wear their brake pads/discs much more evenly than 996's; same size(identical part) rear discs 996(with PCCB or spacer) and 997
I disagree, you are correct the 997 has less forward bias but imo the 996 is perfect. I prefer the forward bias on the 996. I do a lot of my turning under trail braking. It allows quicker rotation under braking. The 997 plows under braking and transitions more slowly. Plus I think it has more rear bias because of the traction control. This allows the electronics much more ability in brake manipulation.
more rear bias, allows the car to rotate more when coming off the brake resulting in over steer. maybe rotating easier means more slowly under braking so it more controllable. I prefer it to do it quicker if I want to rotate more slowly I will brake with less force.
