hydraulic line for the clutch slave cracked
Was at DE and driving through the parking lot and heard a whine, thought it was gearbox whine and then my clutch pedal went really stiff. I parked it and there was a trail of oil what looked like gear oil (not hot at all) gushing out from what looks like the tranny. End up being hydraulic line for the clutch slave cracked.
Anyone ever have this happen? Sounds like it is a difficult thing to change.
if it is the line from the reservoir its easy to replace. not cheap but easy. if it is a line coming from either the p/s reservoir or the p/s pump the motor has to be dropped. both lines wind thru the center of the motor under the manifold
yup need to drop motor to get at wasn't cheap, line I guess cracked because of vibration and age.
I think 4. He showed me the crack. He thinks the last owner's indy when they did the clutch and slave that they tightened it too much and it eventually cracked from that.
