Turbo exhaust nuts and studs.
Getting ready to upgrade the turbo's and swap out exhaust. Got all the bolts loose on both the headers and the exhaust side. Nuts are rusted pretty good.
Found the studs on mcmaster. m8x1.25 30mm long. What are some good nuts to use?
Is there a vendor who sells a complete replacement kit?
Searched through some older threads, couldn't find specifics.
Anyone know anywhere to purchase?
http://www.ecstuning.com/Porsche-200...ger/ES2608646/ This is for the turbos they would have what ever else you would need.
So the kit at ecs doesn't have everything. Sourcing individual washer and bolts.
Here are all the part numbers:
Turbo manifold:
90003103202 Washer
99908405202 Lock Nut
99611121770 Gasket
Exhaust manifold:
90037822709 Hexagon-Head Bolt M 8 X 28
The washers come up anywhere from 5 to 8 dollars for per washer, pretty ridiculous.
Turbo manifold:
90003103202 Washer
99611121770 Gasket
Exhaust manifold:
Just plug those part numbers into the Sunset website referenced above. Below is a cut and paste of my invoice from Sunset a few months ago with the required quantities of each piece. I replaced the turbo heat shields as they were rotted as well. Only thing not on here is the manifold to turbo gaskets. Forgot to order them and got them through dealer. Don't have part numbers on me.
MUFFLER GASKET, LEFT 996-111-217-70 (2) $60.88
MUFFLER NUT 999-084-052-02 (14) $40.88
MUFFLER WASHER 900-031-032-02 (8) $34.88
EXHAUST MANIFOLD GASKET, LEFT 996-111-107-71 (2) $22.22
COVER PLATE, LEFT 996-123-215-75 (1) $58.53
COVER PLATE, RIGHT 996-123-216-74 (1) $57.43
STUD 900-081-059-01 (14) $40.88
EXHAUST MANIFOLD BOLT 900-378-227-09 (18) $61.92
The following 2 users liked this post by Van1:
SCOTT.C (01-29-2020),
user 8298308 (02-22-2022)
