996TT Dual Mass Clutch kit $1,595.00
euge, the price given is for the parts ala "clutch kit"
While there might be other companies offering "other" clutch kits for less. I ask that you send me an email to discuss your driving needs and mods. There are a lot of other issues to contend with. From slave cylinders to the throw out bearing bushings. Another kit might be needed for your driving application ie Friday night drag strip events.
I can only say wonderful things about Kevin's customer service. Hoping to get the clutch kit plus Kevin's dual mass fly wheel installed in the next week. Will post an update once its all done.
Is this kit different from the standard 996 GT2 clutch/pressure plate? From what I've researched, the pressure plate seems to be different on the GT2 stock setup:
Sachs 3082 213 136. How is the 764 pressure plate different?
Thanks in advance!
Thanks in advance!
It's a myth that the GT2 pressure plate is stronger vs the 996TT pressure plate.
The fact is>> the 996GT2, 996TT and 997TT all share the same pressure plate.
The Sachs Race Engineering pressure late (764) is different and is good for 890Nm.
With new T/O bearing bushings and needle bearings>. I would put it at a 5% increase in pedal force with a functioning slave, and accumulator..
