996 Turbo Forum 1999-2005
2001 TT ignition turning off by itself
Old 05-21-2015, 09:26 PM
Nico911
Nico911's Avatar
Default 2001 TT ignition turning off by itself
Seconds after I started the engine on my 2001 TT, the engine shut down by itself, while backing from my parent's drive way. I have the feeling it could have been caused by the key being not properly held in the ignition, for some reason...
Did anybody had this experience ?
Old 05-22-2015, 10:24 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,232 Likes on 1,441 Posts
Are sure it didn't just stall? Do you have a Tip?
Old 05-22-2015, 12:08 PM
Last930
Last930's Avatar
There are threads on replacing the back of the switch - they do wear out. As I recall not too difficult or expensive.
Did it restart? Run ok after that?
Old 05-22-2015, 12:13 PM
Nico911
Nico911's Avatar
I don't think so Carlo, I was stepping on the clutch.
Old 05-22-2015, 12:14 PM
Nico911
Nico911's Avatar
Yes 930, it restarted perfectly and ran ok after on my way back home. I'll keep on eye on the matter.
Old 05-22-2015, 02:27 PM
Smoltz
Smoltz's Avatar
Could also be your fuel pump going (if it hasn't already been replaced).
Old 05-22-2015, 02:57 PM
Carlo_Carrera
The reason I asked is because Tips sometimes stall when shifting into if your battery is low.
Quick Reply: 2001 TT ignition turning off by itself
