Normal boost for a stock 2001 TT
Hi again.
I have a pretty simple question : what is the normal maximum boost level we should get from a non X50 TT ?
if not? there could well be issues ahead if you continue to "test" and visit that boost level however briefly. i hit 1.3 regularly but have a 1.2 ( it's actually technically a 1.1.5! ) tune, with hybrid turbos etc. so thats where it comfortably "lives".
do you know of any mods to your car? if not i'd be a "bit" concerned.
Received 5,413 Likes
Car is stock and I run on 91 octane gas. I wonder if the indicator in the dash can have a false reading. It seems pretty impossible for what I know. It's funny 'cause I either see values like 0.1 or 0.3, or 1.something...
I'll have the car for another issue in a few days in a repair shop so I added this on the shopping list.
When I had low voltage issues due to a bad earth strap mine used to go from 0.3 bar to 1.1 bar with nothing in between. Since that issue has been solved I get a nice smooth progression up to a sustained 1.1 bar. The only time that I've seen more (1.3 bar spike) was when I had to do a full lift off the throttle whilst accelerating a 6000 rpm in third.
Cool, as long as the OP realizes the difference between modified and stock boost (I realize you were probably just illustrating the benefit of fixing the bad earth strap, but obviously 1.1 bar isn't anything he is going to see in his stock Turbo).
No, correct, I was just trying to quantify the zero to hero boost issue in my own context. At the same time I was also seeing 1 bar oil pressure at idle and 2.5 bar at 2500 rpm. I now see 2.1 bar at idle and 4.2 bar at 2500 rpm. I was getting nothing accurate until the voltage went above 13.2V. I think what I was seeing was a low boost reading at lower revs and the boost gauge suddenly becoming accurate at about 5000 rpm as the voltage scraped past 13.2V.
Last edited by mcbit; 05-03-2015 at 01:52 PM. Reason: Corrected 500 rpm to 5000 rpm
At the same time I was also seeing 1 bar oil pressure at idle and 2.5 at 2500 rpm. I now see 2.1 bar at idle and 4.2 bar at 2500 rpm. I was getting nothing accurate until the voltage went above 13.2V. I think what I was seeing was a low boost reading at lower revs and the boost gauge suddenly becoming accurate at about 500 rpm as the voltage scraped past 13.2V.
Since you just bought you car, the most likely explanation for the amount of boost you're seeing is that your has been chipped and is not stock as you believe it to be.
I would be very surprised, I bought the car from it's original owner and I have all maintenance record. I also asked him twice if the car was 100% stock, told me yes both times.
I've noticed similar things on mine and have wondered if I have an un-recorded upgrade. Didn't show up in a pretty good PPI, only some aftermarket diverter valves. Any way to tell DIY using Durametric, or is sleuthing this out only possible with a mechanic or tuner?
