what is it??
what is it??
what is that valve/spring thing between the two oil drain plugs called? and what is it supposed to do? regulate oil flow? would that cause my check engine oil light to come one only to show that the oil is full? thanks oh it's an 01 996tt tip s
You mean this thing to the left of the red arrow? that's the oil line from the crankcase to the oil tank. I think it's finned as a heat sink. Not a spring. I don't think there is anything inside. I imagine JPFlip knows for sure. He's really smart about things like this.
The only one I saw that pop out because of a spring was on the crankcase. According to the oil system diagram it is either a safety valve, item #3 or a pressure limiting valve item#7...
I bet you removed the oil pressure relief valve like jpflip said. It's easy to do by accident rather than the drain plug. It needs to go back in exact same order. I did something similar once. Different 911 but I'll try to find the link.
so what does the pressure relief valve do?
It is there to route too high pressure oil back to the tank or possibly to the intake side of the oil pump, so the rest of the oiling system doesn't experience excessively high oil pressure. The oil filter element, the o-rings of the oil filter housing, even the oil filter housing itself, are at risk of damage if exposed to too much oil pressure.
If your look at the circuit above #3 is the relief valve (safety valve) in case of malfunction of the #7 pressure limiting valve (pressure regulating valve)…If #7 fail and cannot regulate the pressure within the system (remember higher RPM = higher pressure) #3 will open and release the oil pressure back to the crankcase. But the oil pressure is regulated by #7 and when open the oil is going back to the reservoir….
This. ^^
The oil/water heat exchanger(#6) is interesting. If the coils of this exchanger ever leaked, you could get mixing. I assume the oil pressure is always higher than the water pressure to prevent water from ever getting into the oil.
Imho at idle the oil pressure is really low and if it is really warm outside the pressure in the coolant system is a lot higher,even at idle and it will mix. Either way intact! If you end up with foam attach to your oil cap it is a good indication of coolant mix with oil. You remind me something, when I reinstall this heat exchanger after the coolant pipes welding, I was really cautious because if the o-rings under this cooler are not installed properly you will contaminate the system and you don't want to go back in there after the engine is reinstalled ;-(
