what is it??
It might be unrelated, unless you didn't reinstall all the components and it's now open full time at which point it's dumping oil back. I would think however if this was the case, the pressure downstream would be low and you'd get a low oil pressure light. Regardless, I would recheck the installation to make sure all the components are in place and in the exact sequence shown.. If unsure have your mechanic put it on a rack and do a quick check. Then rather than guess, have the codes pulled and see what's tripping the CEL.
