996 Turbo Forum 1999-2005
What's this noise?
Old 03-17-2015, 11:03 PM
kalyan
kalyan's Avatar
Default What's this noise?
After driving from work, I sat in the garage for about a minute idling to cool the turbos, when I heard noise coming from the engine.
Could this be power steering pump? Turbos? Rollers (belt)? SAI pump? Something else?
What do you guys think? Today was the first time I heard it.
Cheers,
-K
Old 03-17-2015, 11:04 PM
jpflip
jpflip's Avatar
Take a look at the steering pump reservoir quantity…
Old 03-17-2015, 11:27 PM
kalyan
kalyan's Avatar
Thanks, Jpflip. I just went and checked. The engine is still warm, so I cannot really check now. But, I checked and it was below the "cold" mark and I am guessing I am low. I will check in the morning when engine will be cold. Repair manual says to start engine and run for approx 20 secs and then check the level.
I will report what I find.
Thanks again...
-K
Old 03-17-2015, 11:34 PM
jpflip
jpflip's Avatar
At the same time take a look at the clutch level reservoir to see if it is not overfilled….Under the bonnet left side under the plastic cover….
Old 03-17-2015, 11:41 PM
rmc1148
rmc1148's Avatar
Good call flip.
Old 03-18-2015, 12:20 PM
kalyan
kalyan's Avatar
Checked the level this morning. It was low and I added a bit to bring it up to the mark just under the "cold" text. I also checked the reservoir in the front and its level was fine.
I drove the car to work today and there was no noise. I will keep an ear on it and if it comes back, I will update here.
Thanks a lot, guys!!
Cheers,
-K
Old 03-18-2015, 12:25 PM
jpflip
jpflip's Avatar
That's great!! Love to see a happy Porsche owner!!!!
Old 03-20-2015, 02:48 PM
MDKK
MDKK's Avatar
Thanks for posting this; I had the same thing happen to me yesterday on mine driving back from work. I was going to record it too. I hear it on the right side of the engine bay, by the oil cap, exact same noise. I will check the steering pump reservoir level. What brand of fluid did you use?
thanks J.P.
Cheers,
-K
Old 03-20-2015, 03:13 PM
"02996ttx50
"02996ttx50's Avatar
thanks J.P.
http://www.pentosin.net/specsheets/pentosin_chf_202.pdf
Old 03-20-2015, 03:24 PM
jpflip
jpflip's Avatar
Just to add to 02996ttx50 answer a little bit of information. The Pentosin CHF11 (previously recommended) is sometimes difficult to found but it is compatible with Pentosin CHF202 which now supersede the CHF11….
http://www.pentosin.net/f_hydraulicfluid.asp
Old 03-20-2015, 03:30 PM
MDKK
MDKK's Avatar
Originally Posted by jpflip
Just to add to 02996ttx50 answer a little bit of information. The Pentosin CHF202 is sometimes difficult to found but it is compatible with Pentosin CHF11S….
Thanks. IF it's low, should I just top it up to the right level with either?
I don't know what's in there to start with so wondering if it's OK just to add to existing fluid.
Old 03-20-2015, 03:42 PM
jpflip
jpflip's Avatar
Just top it up with the compatible Pentosin.
Old 03-20-2015, 03:52 PM
kalyan
kalyan's Avatar
I used the Pentosin CHF11S. Found it at local Advanced Auto Parts. Just add slowly a little at a time.
Old 03-20-2015, 06:04 PM
"02996ttx50
"out here" the 202 has pretty much superseded the 11s. at least thats what i find. it can also be gotten from any m benz dealership. either is fine, same stuff.
although in technical terms jp is actually correct lol with his mention of the ch11s. so, what else might be new!?
Old 03-20-2015, 07:05 PM
jpflip
jpflip's Avatar
Thanks 02996ttx 50 , just realized my mistake….Post 10 corrected….
Quick Reply: What's this noise?
