Wing will not lower on one side
Ya, I searched. I wish people would put their issue in the heading.
Wing will only come down on one side. Other than that works fine. lol
I did push it down with very little effort and removed the fuse.
Only a drop or 2 of fluid in the caps.
Any ideas gents?
Any ideas gents?
It doesn't take much fluid loss for the spoiler to act up. The system has a very small capacity. Sounds like you might be able to bleed it. Some have used power steering fluid with stop leak with success. I did not ! I replaced the system. There is a place that rebuilds the system at a much less cost. They mostly talk cabriolet top system, but they do rebuild spoiler units
Cabriolet Hydraulics
3007 62nd Ave East
Bradenton, FL 34203
941-756-1300
www.cabriolethydraulics.com
3007 62nd Ave East
Bradenton, FL 34203
941-756-1300
It does seem like the wing problem and various solutions should become a sticky!
lucas stop leak and pentosin 50/50 mix. a few fills to adjust for equality btw sides, and if you know ( or have help? ) how to DIY this ( there are full step by step diy's in here.. seen em! ) that will solve your issue. make sure the banjo's are tightened!
Is my problem not unique? Mine will not go down on 1 side.
Everyone else's don't want to go up?
that could be as "simple" as it not raising high enough to trigger the micro-switch. so it doesn't "know" it's supposed to be fuly deployed, and yet "partially" is. just a thought, and a plausible explanation of why it will not signal it to deploy back down. (?!)
Microswitch is only on one side the passenger side. So if the passenger side is the side working okay then the system thinks the drivers side is following suite. I suspect its the lack of fluid causing this or internals of the pump are not pressurizing the ram enough, or the ram is having internal leak, or the system is just plain low.
