996 Turbo Forum 1999-2005
996 turbo psm/abs random failure and idle engine rpm hunting
Old 03-28-2015, 01:38 PM
wross996tt
wross996tt's Avatar
Post the codes you get from PIWIS or PST2 (Porsche diagnostic tools) or Durametric.
Old 04-01-2015, 05:51 PM
alexsahpas
alexsahpas's Avatar
Error code 1101.
Old 04-02-2015, 10:26 PM
horsepowerfarm
horsepowerfarm's Avatar
I experienced the same problem. Intake leak.
Old 04-03-2015, 10:37 PM
alexsahpas
alexsahpas's Avatar
Good day guys,
checking again with porsche diagnostic tool error codes appear(this time) are:
PO102 Hot maff sensor
P1101 input variables,charge measurement
P0175 oxygen sensing adaptation idle range bank 2
P0172 oxygen sensing adaptation idle range bank 1
Old maff measurement 1.12V
New maff measurement 1.32V
maff already changed 3 times(original bosch)
Intake leak tested once(one heavy leak found in port side turbine/intercooler hose colar which arrested).
Air filter installed is new.
If there is another small intake leak do you have any idea of where it might coming from??
Old 04-04-2015, 01:25 PM
wross996tt
wross996tt's Avatar
P0102: 115 Mass air flow sensor – below limit
Possible fault cause
♦ Open circuit
♦ Short circuit to ground
♦ Mass air flow sensor faulty
P1101: Input Variables, charge measurement below/above limit
Possible fault causes:
1 Heavily soiled Throttle
2 Throttle adjusting unit faulty
3 Mass air flow sensor faulty
P0172: Oxygen Sensing Adaptation, Idle Range, Bank 1 –
Below Limit
P0175: Oxygen Sensing Adaptation, Idle Range, Bank 2 –
Below Limit
♦ Incorrect signal from MAF sensor
♦ Fuel pressure too high
♦ Fuel injector leaking
♦ EVAP canister purge valve open
Which Bosch MAF are you using?
PN: 996 606 124 00
Old 04-04-2015, 06:12 PM
alexsahpas
alexsahpas's Avatar
♦ Open circuit
Below Limit
Below Limit
PN: 996 606 124 00
hi,
I. Am using bosch
0 280 218 009
996.606.1224.00 same part number as the one you describe.
Old 04-04-2015, 06:15 PM
alexsahpas
alexsahpas's Avatar
Originally Posted by alexsahpas
hi,
I. Am using bosch
0 280 218 009
Sorry 996.606.124.00
Old 06-08-2015, 06:08 AM
alexsahpas
alexsahpas's Avatar
Good day Mr wross996tt,
i would like to thank you all for your feedback.Finally my problem was solved.Throttle found to be dirty(very thin black carbon/oil film layer) which was creating problems during low RPM where the throttle dumper is almost close.Car now is working perfectly.
Old 06-08-2015, 12:55 PM
wross996tt
wross996tt's Avatar
Glad you got it sorted...
Old 06-08-2015, 04:29 PM
rmc1148
rmc1148's Avatar
Good to hear.
Quick Reply: 996 turbo psm/abs random failure and idle engine rpm hunting
