Annoying door rattle/vibration...FIXED
I am not sure if mine was a speaker screw. If you look at this pic that I lifted from another website, it shows the 996 door with the panel off. If you look at my pic, the screw is a couple of inches below the front lower screw of the airbag. That is not anywhere near the speaker.
Fixed on my 01 996.1 C2 today. The screw in the arm rest is set in plastic and just spins round and round and round. Drilled it out but would undo with some leverage under it probably
Pretty much falling out
Screw is set in a plastic thing that just spins and spins
996Carrera4S (04-13-2021)
Hi Jakerade,
So what did you do with the screw that just spins and spins?
You took it out and left it as it is or replaced with another screw?
I also have the same issue with my 2002 C4S which has really bad rattle noise on the driver (right) side door panel and I'm yet to take the panel off.
Just doing a bit of research before going in.
Funny that this pops up. I have a bad rattle on both sides of my 04 TT Cab. Tried the above fix but the screws were not the issue.
I am now looking into following possible solution :
https://rennlist.com/forums/996-foru...ow-rattle.html
