Entry Level Coilover Options and Opinions
Really? I've had PSS9s on my 964 for 10 years. They have a little surface rust at the tops only. The PSS10 show no signs of rust. Maybe at coastal salt environments?. Billstein makes the factory coilovers for Porsche...they can't be that bad.
I live in Tahoe, so both my Turbo and the 964 have gone through several winters with a ton of snow. My GT3 will stay inside though.
H&R street coil overs are a good choice for the street. They are non adjustable but work well out of the box so there is no need to mess with any adjustments anyway. H&Rs will lower your car more than the PSS10s and will work better at the lower ride heights. When set up per the instructions, your car will be right at GT2 height. I wouldn't mess with anything else. German product, cheap, and durable.
You don't recommend bushings, drop links, sways, etc for street use? OEM stuff is up to snuff?
Bilstein coilovers use H&R springs, H&R coilovers use Bilstein dampers...or at least it used to be that way
Depending on how hard you drive the car, another item I reeeeely like are the rear solid thrust arm bushings and monoball inserts to be installed in the rear LCAs (pictured below). The benefit of these is the fact that they will eliminate any toe change in the rear suspension under load (especially when combined with the toe arms). By eliminating rear suspension movement, you will largely eliminate the exaggerated tire wear people experience in the very inside of the rear tires (assuming you have a good alignment). The harder you drive the car, the more apparent the benefit is on these parts. There is no downside, maybe a tiny bit of extra harshness. If you drive your car in the winter a lot with rain and snow, I'd skip the monoball inserts for corrosion reasons. Just do the solid T/A bushings. Get the non adjustable ones instead of the adjustable ones as pictured below. You will have to remove your rear LCAs, press out the old rubber bushings, and press in the new ones. Tarett sells these. Again, for just a street car, these are probably not necessary. Porsche did a good job with these cars out of the box. Hope that helps..
Now I've got to go get the car up on the lift again. My PSS10s still look new! The PSS9s not so much, but they are pretty old now. They still feel great though.
I installed RSS clubsports on my 03 TT this spring.
The car is transformed from a trackable street car to a streetable track car. Think Go-Kart type handling!
I couldn't be happier with the result. The downside, it is imperative to not hit road irregularities, it will scare the hell out of you. The upside, you can feel the car, smooth roads are much better, and track times are significantly reduced.
H&R customer service out west is very helpful.
If you are installing yourself, I would be glad to provide lessons learned.
The only must that I recall is adjustable toe links. The kit came with drop links which I used and work fine, but adjustable are preferred as they can be used to improve corner balancing.
What about the stock X73 suspension? Gert at Carnewal sells the whole kit and the folks who have it rave. It's a nice entry level step up towards track performance that is still Porsche quality.
Cheers
Mikey
Cheers
Mikey
almost impossible to find any new from a vendor ( even gert ) x73 any longer. this is what i use, and it suits the bill perfectly as what was asked for. an entry level setup. there aren't 10 guys here this wouldn't work for. it's bilstein by the way. not for nothin"
http://www.lindseyracing.com/LR/Pors...IL-HDMO30.html
you will NOT be sorry. OEM baby.. oh yeah... did i mention? only 1300 bucks but you need some h&r springs
