Bailey Diverter Valves
The DV30 is indeed the correct valve, but good luck locating a pair. I've been asking Bailey for over a year, they haven't done a production run in a while, and their US distributor AWE tuning doesn't have any last time I checked. That may have changed, I finally gave up waiting months ago. A better and less expensive choice are the 710n's IMO.
Cheers
Mikey
Cheers
Mikey
Yes, DV30s. I've had those on my car since 2009.
New 710n's are crap IMO. Bosch no longer makes them, a company called Kayser does. I got two in a row that honked like geese and switched them out for some Forge 007 DV's.
Thanks. I'll try to get them in the US. I got my X73 from Carnewal, and Gert was extremely helpful, but going through the customs hassle for diverter valves seems like a bit much.
F pipe and Bailey's
I pressurized the intake, and thought I felt some air around the F pipe area. So, I took it out and checked. The F pipe wasn't split or damaged, and the Bailey's appear to work fine.
I noted that there is one of the black and white check valves under the assembly. While I'm here, should I replace it? Is there anything else I should be replacing or R+R?
