2WD conversion - what is the correct way to convert?
i was referring more to the pic that powder hound posted. all porsche em but not turbo parts yet makes the car better. for me i threw the manual out long ago. its all about going fast for me i don't care if its porsche aftermarket or nissan. if it can fit make hp and take me down the 1/8 1/4 1/2 or mile I'm in!
i will use oem gt2/3 parts whenever possible and only look at other options that make sense and are not available oem. we use our cars differently, and although i respect what you do with yours, and all the effort/work you put in it! i do still believe that if porsche motorsports wanted to build out the car as you have? they would've. but then it wouldn't be the first time ( even today ) i've been wrong. whatever makes ya happy is good by me..
but nissan? LOL. cmon now?! yer just joshin
OK, I have a GT2 in the garage but don't know that rolling under it will still give me the answer I want. NO place I can find mentions anything done to output on the TT output.
Im using a 996TT box in a rwd application. Do I simply install "as in" and just ignore the fact that it once was a 4wd box? So we aren't changing the box at all to use it in 2wd applications? I know this is likely me making something out of nothing, but too pricey to screw up because I didn't ask the obvious.
No, GT2 is good. It's another project that I'm installing a TT box into. Thanks for answers. I've read and read and read threads here and 6spd and couldn't find reference beyond "disconnect drive shaft".
