During Hard acceleration PSM, ABS and Brake Fluid lights come on.
I have a 2001 911 turbo with 68,000 km. During a hard acceleration, PSM, ABS and Brake Fluid lights come on. When I restart the engine, these lights turn off but the PSM remains deactivated.
I have read lots of forums and none of them really address my situation. Some of the forums say that battery fluid shifts during a hard acceleration and can cause these lights to come on. I have changed the battery and the lights still come on.
These lights started to come on after I changed the drive belt. In order the changed the drive belt, I had to take of the air box and MAF. Some of the forums suggest that MAF sensor could be faulty. I was very careful with the MAF sensor and I didn’t drop it when I changed the drive belt. I believe if the MAF sensor is faulty, then I should get a fault code.
I don’t know if the brake fluid level senor is faulty. I don’t know how to test it. However, when I did disconnect the brake fluid sensor, the PSM and brake fluid lights came on. Then, I reconnected, both lights turned off.
If anyone has a suggestion, please reply to this post. I would greatly appreciate it!
I think the MAF is original. Im the second owner. I don't know if it has been changed. The car is 2001 with 68km. can I test the MAF without the porsche scan tool? If the MAF is faulty, why would it throw brake fluid light?
They can be checked with a multimeter and a MAF can cause all kinds of weird things. It could be a multitude of things but with the hard acceleration causing it I would guess MAF.
Today I did clean the MAF sensor and no change. Today, the lights came on under a moderate acceleration on a bend when I made the rear wheels lose traction little bit. I then restarted the car and lights went off. However, the PSM hasn't worked ever since the lights started to coming on. Even when I restart the car and the lights turn off, I can spin the rear wheels, which means the PSM doesn't work.
Also, I did check the boost and it seems like working.
