Oil in plenum
Oil in plenum
I pulled off the throttle body in my '02tt while replacing the oil pressure sender and noticed a thin film of oil in the plenum. Is this normal? There's been no change in performance, mileage hasn't changed, no excess oil use.
TIA
TIA
A little bit is usually considered normal. The oil gets past the the seals in the oil fed bearings in the turbos. The turbos get so hot they can't really be sealed perfectly.
