996 Turbo Forum 1999-2005
carbon fiber trim
Old 09-17-2014, 11:07 PM
otolith
otolith's Avatar
Default carbon fiber trim
I am looking to replace the carbon fiber trim on a 03 996 tt. It has curled on itself and is peeling off. Any suggestions regarding repair or replacement. I have not found an ideal replacement on either suncoast or pellican.
The trim in question is on the dash hugging the windshield.
Old 09-18-2014, 08:25 AM
RDS928S
RDS928S's Avatar
www.macarbon.com
www.dbcarbon.com
DB in Germany has really good pricing.
Good luck
Old 09-18-2014, 11:14 AM
jbossolo
jbossolo's Avatar
I'll vouch for MAcarbon. Highest quality. Mine's been on car for over 10 years, not an issue. No fading, peeling, nothing. For sun-exposed areas I'd recommend this product- 303 Aerospace protectant.
Old 09-18-2014, 04:53 PM
wross996tt
wross996tt's Avatar
++++exactly
Old 09-19-2014, 12:05 AM
Kevinmacd
Kevinmacd's Avatar
Yup typical. I replaced mine, found them on ebay for around $300 each. If you buy from the dealer on the internet expect to pay $600 each. You can remove the entire trim piece use some gorilla glue sparingly, heat up the carbon strip and clamp. I do mean use the gorilla glue sparingly since it expands and turns white when dry. Moisten the trim piece where the carbon fiber sits, and apply very thin bead of gorilla glue to the center of the defroster trim pieces, then clamp. the carbon fiber has to be heated to sit down evenly. Hair dryer works.
Its easy to remove the trim piece, you have to remove the side vent, pull it out, remove the alarm lens, then the A column trim by pulling on it, then the trim piece pulls out.
Another alternative, buy the trim on ebay without the carbon fiber trim and replace, or go after market like someone said Macarbon or ROTec.
Old 09-21-2014, 11:55 PM
John D II
Basic Sponsor
John D II's Avatar
I restored mine and it came out perfectly. It's been on 3 years now with no issues, many days in the hot sun. I just peeled the original CF off the leather dash and then the clear coat came right off by running the CF strip over the edge of a counter at a 90 degree angle and just pulling the CF along. The clear would just break off rather than make the 90 gedree turn downward. I used aerosol clear coat and gave it several coats to match the OEM thickess. It still looks showroom new, no bubbling, warping, lifting, etc....and it's a very inexpensive fix. I used JB weld to cement it back down.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
Old 09-23-2014, 02:21 PM
uschoice
uschoice's Avatar
John, what did you do to copy the curvature of the dash before you clear coated it. If you clear coat it while laying flat, will it crack when you glue it back down to the dash? I'm talking about the cf strips that run from the defroster vents down to the corner vent outlets.
Thanks, David
Old 09-23-2014, 03:54 PM
John D II
Basic Sponsor
John D II's Avatar
Thanks, David
The CF is die cut from a sheet and it retains the exact size and shape to fit right in place. I just laid it flat on a sheet of plywood and raised it by placing narrow wood pieces under it so the edges were suspended in the air and sprayed it about 14 coats to get the oem thickness. Light sand after every few coats.
Old 04-18-2016, 02:31 AM
PorscheDA
PorscheDA's Avatar
Thanks for the info John I think I'm going to do mine next weekend. How long did you let the clear coat dry before doing another coat or sanding?
Old 04-18-2016, 03:07 AM
John D II
Basic Sponsor
John D II's Avatar
I'm sorry, I don't recall exactly...I'm thinking I did about 5-6 coats and lightly sanded after a few hours and sprayed again another 5-6 coats and sanded again. Then did the final 2-3 coats. I believe it was all in one day.
Old 04-18-2016, 11:52 AM
PorscheDA
PorscheDA's Avatar
Thanks John we will see how it comes out..
Quick Reply: carbon fiber trim
