2001 996 Turbo maintenance question
I just purchased a very nice, well maintained 2001 turbo tiptronic with 17,500 miles (18,130 now, I drove it home!). My plan is to use it as a nice weather only daily driver. After looking at all the service records, it looks like all the fluids were replaced regularly except the front differential and the transmission fluid. I also don't know if there is a transfer case or not (or is that just on 4x4 trucks?).
My question is: Should I replace the transmission fluid and differential fluid? I know there are many different schools of thought on this. I am very proactive with maintenance and want to start with everything fresh. I told the mechanic at Porsche (whom I'm friends with) that I wanted to do that and he was adamantly against doing it. He said that I would be asking for trouble and it's best left alone unless there is a leak or other problem with the transmission.
I have an appointment on Wednesday for a safety inspection and wanted to know if I should listen to the mechanic, or my gut? How do the people on this board feel about it?
^^^^ this ^^^^ Why not establish a known baseline and erase any doubts? I can't imagine why changing fluids in a tip would cause any problems. Oh, no transfer case on these puppies so don't go doing any rock crawling!
I agree with the others. Change the trans fluid now and then do not touch it again until there is an issue. I change my tranny fluid and filter at 40k miles while I had the engine out for the coolant pipes to be welded. I also had the front and rear diff fluid changed.
The proper replacement trans fluid is now called Shell ATF134. The ZF tranny in our TTs is almost exactly the same unit used in 2005-2009 Jeep Grand Cherokees, 1999-2007 Mercedes MLs, early 2000s Sprinter vans and AMG McLaren SLRs.
My dealer Barrier Porsche keeps telling me that the fluid is good for 100k and even then it is usually clean when they drain it so I wouldn't worry it. I'm going to have mine done at 50k next year just for the hell of it. I think brake fluid and anti-freeze are more likely to be needed by years instead of miles.
Dan
Dan
Dan
Dan
You are correct about the brake fluid and anti-freeze. Those both should be change by time interval not miles. I had my anti-freeze replaced when the engine was out for the coolant pipes. I will probably never change it again. Brake fluid I change every year because of track driving.
i know it isn't "true" but i often wonder if porsche advises me to only change my transmission oil every 90k miles(!?) in the hope i'll let them open it up once it needs to be repaired lol
got my '07 997.1TT Tip 18 months ago- now has 24.5k miles- Just had dealer install EP1 exhaust, also new plugs/coil packs, trans fluid/filter, front/rear diff fluids & belt replaced. Plan on keeping car long while.-
Few months back wife's 07 Boxster S with 58k miles- had water pump, tstat, antifreeze, tip filter/fluid, plugs/coil packs replaced. old water pump bearing/impeller looked fine- PM is important IMHO.
Many yrs ago wife's lexus developed trans issues- no reverse- was like neutral- i'd not ever changed trans filter or fluid- after trans repair- changed filter every few yrs-
Porsche also says oil changes every 9k miles. I cut that in half or once a year whatever comes first!
Lot of manufacturers claim 100K rans fluid changes. To many friends who adhered to that rule had trans work done. Let me qualify, no one I know on the Porsche trip. My opinion would do trip trans fluid every 30K
I just dropped my car off with Mike Callas at Rennsport Works for some work (brake fluid flush, diverter valve replacement, boost leak test, air filter replacement). I asked Mike if I should change out my differential and transmission fluid (I'm at 64K miles) and he said "no, no need at this point...change at 90K miles." Given that he's the man when it comes to Porsches, as far as I'm concerned, I'm sticking with his advice.
You stated you are proactive with maintenance so go ahead and have the fluids changed. The service is not that expensive and it gives you some peace of mind you are helping perhaps to extend the life of the hardware.
Do the front diff and tranny/diff too. It doesn't experience nearly the load/forces the rear diff does but what the heck.
Had the tranny/diff fluid changed in my 02 Boxster -- at 60K miles -- and every 60K miles thereafter. The odo just rolled over 285K miles and the tranny shows no signs the miles have had any effect.
While you are in the mood have the coolant drained and replaced with fresh coolant.
