996 Turbo Forum 1999-2005
Normal boost for a non flashed car?
Old 08-25-2014, 11:20 AM
okiedude
okiedude's Avatar
Smile Normal boost for a non flashed car?
Noob question, I searched, but did not find the answer.
2003 996TT, 35K miles, bone stock. At WOT in 3rd/4th I am seeing .6 Bar. A friend who just sold his 996TT said I should see .8 or .9, thoughts?
At 11 years old, is it time to go through hoses and look for a leak/or serial replacement? Does someone sell a fairly comprehensive hose "kit"?
TIA
Old 08-25-2014, 11:28 AM
neanicu
neanicu's Avatar
0.7 Bar is maximum on stock cars.
Old 08-25-2014, 12:04 PM
okiedude
okiedude's Avatar
Thanks, I saw it hit .7 for a split second a few times, then was constant at .6, so my old car is not falling apart like my old body!
Old 08-25-2014, 12:11 PM
Macster
Macster's Avatar
TIA
Normal based on my experience and what I've been told.
The DME attempts to meet the torque demand desired by the the driver and signaled by the e-gas system. If it can do this with in this case 0.6 bar boost that's all you'll see.
In some cases you will see 0.7 bar boost and in some special case -- at higher elevations is my experience -- even higher levels of boost: 0.8 bar, even 0.9 bar; with a stock but in good tune 996 Turbo.
Unless you have signs of a boost leak -- and so far based on what you've posted you don't -- you do not have to bother with the hoses. The hoses on my 03 Turbo are original and are just fine. Techs tell me they are normally quite long lived. Most often when they leak is it because they were removed for some reason -- plugs maybe -- and re-installed incorrectly.
Be sure the plugs are ok. They are due to be changed at rather low miles compared to other cars. They are also due to be changed on time too. Be sure you use high quality gasoline of the right octane grade and buy from a busy station. Do not overfill the engine with oil. How's the engine air filter? If original it should be replaced. Oklahoma (and Kansas and other states in that general region) can have high amounts of particulate matter in the air. (Drive through say Kansas in the fall when everyone it seems is either plowing dry fields, burning off ground cover, or burning piles of brush and you would think you are driving through a post-apocalypse zombie land. The air is so thick with smoke and dust particles you can cut it with a knife.)
Old 08-25-2014, 04:18 PM
okiedude
okiedude's Avatar
Thanks Mac, I appreciate the reinforcement. Plugs are fairly recent, last 5K miles. Filter is new 2K ago. Biggest issue we have is crapola gas. We are pretty limited to 91 octane here in OK. I do try and buy from the same 2-3 stations which are busy ones. I have 6 cars that require premium, I hate the 91, but know about using stations that will turn their storage tanks on a regular basis. Engine oil is good, per the auto-check. I do wish I could check a dipstick-LOL!
If it ain't broke don't fix it!
Old 08-25-2014, 04:20 PM
okiedude
okiedude's Avatar
Does the ecu compensate for my crap gas, self learning? Or is that wishful thinking.
Old 08-25-2014, 04:38 PM
rmc1148
rmc1148's Avatar
It should retard timing to stop pre-detonation which will mean less performance. Cant you get 93 where you live.
neanicu
neanicu's Avatar
91 gas is fine.
Read your owner's manual. It's stated in there that if you must run gas with octane lower than 91,you can do so on a short basis and the computer will retard timing based on knock sensor input. In plain English,it won't run as good but it'll be ok for a short time.
Old 08-25-2014, 05:33 PM
Kevinmacd
Kevinmacd's Avatar
X50 stock will boost to .8bar. I see .7 based on gear and rpm!
Old 08-25-2014, 05:49 PM
"02996ttx50
"02996ttx50's Avatar
the car gets used to 91. 93 is much better. but a few gals of 100 mixed bringing it higher is even better.
Old 08-25-2014, 10:29 PM
"02996ttx50
your ecu is not flashed?! those were my numbers x50 stock also
mdurbahn
mdurbahn's Avatar
I get .8/,9 consistently with all stock 2002 6spd at 7000' on 91 octane
Old 08-25-2014, 11:13 PM
geetee
geetee's Avatar
like ppl mentioned.....6 to .7 that's only part of the story though
these cars are old even with low mileage. You really need to do a boost leak test. You'd be amazed at how many areas you can have a boost leak even on a stock car. It makes a huge different if you have a leak or not.
Old 08-25-2014, 11:52 PM
okiedude
okiedude's Avatar
I can get 93, but, it's only available at two stations in the entire OKC metro area (million + people). It's about twice the price of 91. I do go there to get 93 for my Testarossa, and have on occasion for the TT, but it's quite out of the way. 91 is the norm, the big deal here is whether it's 100% gas or e10. A number of stations offer both.
I can also check for boost leaks, we have to occasionally do it with our Subaru's. I assume there are a few threads on checking for leaks?
Old 08-26-2014, 12:10 AM
rmc1148
rmc1148's Avatar
Testarossa nice! 91 should be fine of course 93 better. Here and on 6spd there are good threads and diys do some searches..
Quick Reply: Normal boost for a non flashed car?
