Turbo replacement gasket kit?
While browsing random vendors last week I thought I saw a listing for a turbo swap gasket kit, that contained all the gaskets and o-rings that needed replacing when the turbos were replaced. I can't seem to find it now. Does anyone know who sells all the exhaust gaskets and coolant/oil o-rings to the turbo in a kit, or have a list of part numbers to order separately? If not, I'll pull the PET diagram and go through it. I'm replacing a turbo shortly and need to get all the gaskets and seals in hand first.
Thanks,
Sam
Thanks,
Sam
engine builder supply can get you whatever you want. simply tell them what your doing and they will build you a gasket kit. i have a complete engine rebuild kit and a coolant line replacement kit from them. great folks
There is only 5 oring/gaskets..
Large exhaust flange metal oring
Small inlet exhaust flange metal oring
Oil sumpo tank plug sealing ring Aluminum
Oil sump tank to turbocharger Rubber Black Viton
Copper check valve oring
I'll add part number later...
