RWD conversion - do I need new spindles?
And I would lose the signal for ABS too, as the tooth portion of the CV would be missing.
So basically I need to find "tension bolts" as described by powderhound that would fit my car, or build it from regular CV joints.
Now I'm confused - how did folks who converted their TT to RWD do?
They seem to say it's a one hour, piece of cake job?!
Honestly, the best way to do the RWD conversion properly and correct the goofy TT front end geometry is to swap to the GT2 uprights with the associated hardware. If you are also planning on a suspension upgrade, that would be a perfect time to do to minimize costs. A fully functioning TT front drive system is worth about $2K which largely covers the GT2 front end conversion.
[url=https://flic.kr/p/g5SLAd]
pwderhound if you know someone who wants to spend 2000$ for the front drive setup let me know!! i haven't had a bite on any of the parts
mine has the jrz coil overs and i didn't have to change any suspension settings when i removed them. brakes lines and steering linkage was all that was needed to get the coil over out.
Thanks a bunch!
Powdrhound that's exactly what I had in mind, so thanks for the pic. I like to keep original parts avail for the car in case of sale. So I'll find a pair of worn CVs and will turn them if there's more than an ounce to save otherwise will keep them as they are once dismantled...
[url=https://flic.kr/p/fzqFcw]
I’m considering doing the RWD conversion on my turbo as well and so I’ve started to do a bit of research.
A couple of questions (powdrhound or anybody else?)
Stub axle AKA “tension bolt”; you’ve said that the GT2 tension bolt will not work, however the Carrera, the Carrera 4 and the Turbo all use the same wheel hub, as well as the wheel bearing so I’d be surprised if the tension bolt from a Carrera cannot be used, comments? I saw one of your posts saying the GT2 tension bolt will NOT work, but I didn’t see an explanation or pictures nor any comments on the Carrera tension bolt.
Suspension uprights:
I’m curious how different the turbo upright is from the 2wd Carrera upright to “fix” front geometry. I know the GT2/GT3 use different front uprights but my curiosity is to what degree. I do know that the Carrera uprights WILL accept GT2/GT3 coil overs, found that out when I was converting a 996 Carrera into a track car some years ago...
Thanks for the response. I see indeed that the tension bolt is different between the GT2 and the turbo. That is expected though, considering that the turbo part is integral to the front axle/CV joint. Are you saying the tooted side (for ABS sensor pick up) of the tension bolt on the GT2 would be too big to fit in the space provided on a turbo upright? Perhaps I’m missing something but I don’t see a side by side comparison.
Also, part #s indicate that the 996 GT2 tension bolt can be used on the Carrera (and a Boxster, GT3, Cayman, 991, etc.), and since all these cars use the same wheel bearing AND wheel hub.
Let me ask it this way (and pardon me if I’m making you repeat yourself)- Have you tried the GT2 tension bolt in the turbo carrier or had them side by side to see an obvious incompatibility? I don’t have a sense of scale when I see different pictures showing the parts.
The GT2 tension bolt will fit in all the RWD cars because they have different uprights that the TT or C4. It's the size of the opening in the upright that drives the fit of the tension bolt, not the bearing or wheel hub.
The GT2 tension bolt will not fit in the TT upright. Trust me on this....
I appreciate the response, saves me from locating tension bolts just to end up having to take apart the CV joint. BTW, I’ve followed a lot of what you’ve done to your 996, looks like a rather enjoyable car thanks for the pics and documenting it also.
No worries. Good luck with your project...
