Alternator / Regulator / Battery?
#31
I have the same numbers as you posted it's been that way for 2.5 years since I put a new alternator in my car. I only really notice it dip close to 12.3 volts whens its over 110 degrees out here in Arizona with AC on low, radio, and headlights on at stop lights or traffic is most noticeable. A few Porsche mechanics I have talked to says it's completely normal on are cars?
#32
From what i have read, it could be wiring is getting old and corroded....not sure.
I think Arizona climate is harder on batteries and alternators.
#33
Hey Mark,
Check the engine to body ground, located near the passenger side turbo.
Rob
Rob
#35
Anything above 12V with all of the accessories in the ON position is considered normal at IDLE. And notice I emphasize IDLE. You need to raise the RPM at that point and the voltage should go up. Then your alternator is fine.
#36
#40
glad it worked out!
#41
I'm sorry,but I'm not buying it...
#42
I use to buy and sell a lot of cars and cannot name the problems I solved by cleaning grounds and contacts on fuses etc. Vacuum lines being replaced usually fixed the other problems .
#43
Push me hard enough and I'll make a video.
#44
when you say all those cars were at 'little over 12', can you be specific?
should all be ~12.5+, or the charging system/battery is undersized
#45
The 996TT showed 12.3V.
The 997GTS showed 12.5V,but no heated seats on this one.
My suspicion is that the OP didn't load up the system with so many accessories.
Again,put AC On full blast,heated seats-driver and passenger on high,Rear defroster(very important),high beam On and have the car at IDLE(again very important-we're not talking while driving here or a certain RPM-we're talking IDLE).
