Steering Column Switch
Our 996 Turbo steering column switch needs to be replaced, it does not hold in place the right turn signal. Left works fine. I disassembled to inspect and noticed something had broken internally in the mechanism.
Is it possible to replace with a 3 stalk part and add on the OBC stalk from the existing switch or do I have to replace with a 4 stalk part?
The car has the 4 stalk and OBC...not sure if all 996 Turbos do or not but ours does.
It is a 2002.
TIA.
Brett H.
It is a 2002.
TIA.
Brett H.
