996 Turbo Forum 1999-2005
Misfire all cyl after DE
Old 07-27-2013, 02:38 PM
  #76
neanicu
neanicu's Avatar
Originally Posted by judd944
The car was at idle then. If I revved the engine they would go near zero then down to -7 and up to +4
Ok,as soon as you start the engine,the computer looks at the Long Fuel trim numbers and starts from there. The Long fuel trim is like a memory you have from the past.
Once the O2 sensors go into Closed loop,the computer adjusts the mixture to keep the O2s " happy " switching between 0 to 1 V in most cars.
If your LT fuel trim starts at -7.8 which meant pulling fuel away,the computer will start adding fuel to keep the O2s happy,so your ST fuel trim will go positive for balance.
When you raise the RPM the injectors will squirt more fuel so the computer will intervene to keep the balance.
Again,all these numbers seem normal to me. Looks like the mixture is good where it is...
We need to start looking elsewhere...
Old 07-27-2013, 03:34 PM
  #77
judd944
judd944's Avatar
Should I swap diverter vales?
Old 07-27-2013, 04:38 PM
  #78
neanicu
neanicu's Avatar
Can't tell you 100%...
Further diagnostic might be needed before starting " throwing parts at it "... Personally I don't like this approach...it can get expensive fast!
Old 07-27-2013, 05:14 PM
  #79
Kevin
Kevin's Avatar
DV's can be tested. Use a Mity Vac > connect to the top fittings and pull vacuum... It should hold 28 inches.. If it doesn't you have failed DV's and/or ones that need to be rebuilt/cleaned.
Old 07-27-2013, 07:22 PM
  #80
judd944
judd944's Avatar
Default few runs today
I made a few more datalogs in 6th gear this afternoon. one with the MAF connected one without. It felt like it rumbled more without the MAF than with it connected. I also was going up a slight grade so that could be it.
Old 07-27-2013, 07:25 PM
  #81
judd944
judd944's Avatar
wish I would have bought the mity vac instead of the vacuum gauge I bought last week.
Old 07-28-2013, 11:34 AM
  #82
judd944
judd944's Avatar
I was reading about the cam solenoid bracket like crazy last night on here and 6-speed. it sounds "common" and the error was misfires on one bank.
I am kicking myself for not looking at it better when I had it apart. I am going to check vacuum tonight if I get a chance to see how it responds when I hit the throttle.
And there was much rejoicing in the land of the GT1 block!
Old 07-28-2013, 11:39 AM
  #83
judd944
judd944's Avatar
broken bracket on Bank 1 where I was getting the misfires. the oil only came out because I removed it briefly. I need to order a new bracket before removing this one.
Old 07-28-2013, 12:11 PM
  #84
neanicu
neanicu's Avatar
Old 07-28-2013, 12:24 PM
  #85
judd944
judd944's Avatar
Thanks for everyone's help, I learned more about my car in the last few weeks and feel good finding a common problem on the "outside" of the engine!
Old 07-28-2013, 02:39 PM
  #86
PAULUNM
PAULUNM's Avatar
I think it's a good idea to proactively replace these brackets when you're in there for plugs and coils. I know I did.
Old 07-28-2013, 08:46 PM
  #87
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,232 Likes on 1,441 Posts
Good job, nice and simple, sorry no one mentioned it when to were doing your plugs.
Old 08-01-2013, 10:26 PM
  #88
judd944
judd944's Avatar
New bracket installed on both sides. Test drive went well. Car is running great. Thanks everyone!
Quick Reply: Misfire all cyl after DE
