emergency bonnet release ??
I have electric locks for the engine and front bonnet. In the case of a problem with the engine lock I have attached a litle handle to the cable , that can be pulled easily from under the car behind the bumper. Any DIY mod I can do for the front ??
In the case of a problem I would like to be able to have a plan B...
Are you afraid the cable from the electric release will break or that your battery will die and thus you will not be able to open the bonnet?
If you are afraid of a dead battery there are instructions in the manual how to trigger the rear hatch to open with a jumper battery connected to the fuse box in the driver side kick panel.
