996 Turbo Forum 1999-2005
ABS Pump needs replacing
Old 03-27-2015, 12:35 AM
jpflip
jpflip's Avatar
SpawnyWhippet , just found some interesting informations about the ABS hydraulic unit. Your part numbers are not similar with the ones mention in the repair manual but , I think it is important, there is a mention about the combination hydraulic unit/rate−of−turn sensor!!! Just for your information interesting reading on page 784 to 787….
Old 03-29-2015, 09:43 PM
SpawnyWhippet
SpawnyWhippet's Avatar
I only have the Bentleys manual, are you referring to the Porsche workshop manuals? I don't have access to a set.
Old 03-29-2015, 10:17 PM
jpflip
jpflip's Avatar
Yes I am talking about the repair manual and yes you can have access to this very helpful manual here: Direct download, thanks to $manager on 6speed!!!
carolinainvestmentadvisors.com/Documents/996TTREPAIRMANUAL.pdf?31
Old 03-30-2015, 12:50 PM
SpawnyWhippet
Thats great, thanks very much. Gives me a new avenue to explore.
Old 03-30-2015, 01:19 PM
jpflip
jpflip's Avatar
Another avenue is to check properly the wire bundle from each wheel abs sensor. It is important to know the continuity check is not enough to troubleshoot your wiring. The ABS is looking at resistance! If per example the wiring is rubbing or cracking somewhere you still get continuity but the resistance is lower that will trigger a message. Lately I've read about many problem involving the abs wires that cracked and you can buy new one…Take a look at this interesting thread: http://www.6speedonline.com/forums/9...already-8.html
Old 03-30-2015, 03:32 PM
rmc1148
rmc1148's Avatar
Interesting I wouldn't think the wiring would be available good one Flip.
Quick Reply: ABS Pump needs replacing
