996 Turbo Forum 1999-2005
Taillight repairs
Old 12-03-2012, 01:55 PM
CincyScott
CincyScott's Avatar
Originally Posted by jpflip
I looked at this one last night, but do have all of the pieces to get them back together, so I'm going to try to fabricate a top/bottom reinforcement, rather than have to make a whole new bracket.
Old 12-03-2012, 09:07 PM
Kevinmacd
Kevinmacd's Avatar
Any good 2 part epoxy. Being you have all the pieces back together, use the epoxy over the super glue repair and then epoxy the washers. Think then you will have no more issues.give it good time to cure.
Old 12-11-2012, 01:13 AM
Laguna Seca
Laguna Seca's Avatar
Make sure the surface is ultra clean! Otherwise it will separate!
Old 12-11-2012, 03:46 PM
SSST
SSST's Avatar
I used black nylon washers and JB Weld on mine. That was about 14 months ago and no problems so far. Agree on getting the surface clean. I also scuffed the surfaces with 100 grit before applying the epoxy.
Old 12-12-2012, 12:44 AM
Kevinmacd
Kevinmacd's Avatar
Nylon does not work very well 2 part epoxy. I would use metal washers.
Old 12-17-2012, 02:20 AM
Shiftgate
3rd Gear
Shiftgate's Avatar
LED s are supposed to be available early next year for the 996 turbo. I myself are on the waiting list for the first batch. Apparently going to list for $600 for a pair and look like 997 taillights. I'd hold out before replacing the oems with other oems. Ps my tabs are broken as well.
Here's the link. It's crazy long but the original poster says that they are Definetly being made so add yourself to the list.
http://www.6speedonline.com/forums/9...sponsored.html
Old 09-23-2016, 12:35 PM
Ck986
Ck986's Avatar
The light savers are a great idea. Mine were still fully intact, but cracked. So I took my plastic soldering iron and welded it back together and also added material on the rear of the bracket. I then covered the lights and sprayed the brackets satin black, mine look good as new.
Old 09-24-2016, 06:34 AM
DaveCarrera4
DaveCarrera4's Avatar
Tail light savers even work if there are a few pieces missing. I really like mine, they hide where I tried to epoxy the parts back together - which eventually failed again.
Old 09-24-2016, 06:24 PM
TheDeckMan
TheDeckMan's Avatar
Put mine in this weekend, work great
Quick Reply: Taillight repairs
