996 Turbo Forum 1999-2005
Oil Change DIY (pics)
Old 01-20-2011, 06:32 PM
pwarnery
pwarnery's Avatar
I followed Kevin's advice last time I changed my oil and added 1/2 quart through the oil filter. When I started the car there was no noise whatsoever from the the engine, like what you might hear when the car hasn't been started for a couple of weeks. As a matter of fact the oil pressure light never even glowed for any amount of time as it does on some engines after an oil change.
Old 01-20-2011, 07:03 PM
LVDell
LVDell's Avatar
So with pulling the fuse, how long do you "crank it over"?
Also, Kevin, can you please verify Jon's statement about doing this beforehand as well? THanks!
Old 01-20-2011, 07:09 PM
Kevin
Kevin's Avatar
To prevent the engine from firing over with fuel trapped in the injector. Please pull/remove the C4 fuse BEFORE you drain your engine oil. Crank the engine over and you might get a quick fire on a couple cylinders..
Do your engine oil change, pour a little oil into the center of the oil filter element (one quart is nice) Once filled, crank the engine over (5 to 8 second in duration) YOu might have to do this 2 or 3 times.. We want to see the pressure gauge move up past 2 bars.
Refit the fuse and start your engine.
This should be a STICKY...
Old 01-20-2011, 07:33 PM
LVDell
LVDell's Avatar
Perfect explanation. Thanks Kevin
Old 01-21-2011, 11:19 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Done.
Old 01-21-2011, 11:55 AM
LVDell
LVDell's Avatar
Next oil change I will take video and post the link.
Old 01-21-2011, 07:47 PM
porka
porka's Avatar
i need a rack!
Old 01-22-2011, 10:58 AM
LVDell
LVDell's Avatar
Greatest investment for my garage I ever made. I have been able to do more DIY projects that I ever imagined. Plus, all the local guys come over and get good use out of it as well. If you have the space it is sooooooooooo worth it.
Old 01-22-2011, 07:52 PM
cannon1000
cannon1000's Avatar
Thanks! Can we move to permanent DIY section?
Old 01-22-2011, 07:57 PM
LVDell
LVDell's Avatar
The problem is we don't have a 996 Turbo DIY section.
I'll be doing gearbox oil change, brakes, and brake fluid in my next installment which I will post up. Maybe we can have a STICKY for the DIY with the links to the DIY's in the Turbo forum. Thoughts?
I'll post up a thread (cough cough Lewis) that can get stickified and I'll make sure to keep adding DIY threads to the first post.
Old 08-05-2011, 08:20 PM
ek9max
3rd Gear
ek9max's Avatar
Awesome. trying it myself tomorrow!
Old 08-06-2011, 10:38 AM
Land Jet
Land Jet's Avatar
Funny, I take satisfaction in that I didn't have to do it myself.
Old 08-07-2011, 12:06 PM
JG 996T
JG 996T's Avatar
Changed my oil and filter yesterday. Last oil change was done by an Indy who charged me extra for the time spent trying to loosen turbo drain plugs... Well I had an extremely hard time loosening said plugs, and when I finally managed to remove passenger side : no washer!
Couldn't remove driver side. I assume there is no washer on that side also. Anybody know the part number for the turbo drain plugs (not the washers, the Plugs).
Thanks to Dell and Streather for the DiY assist.
Old 08-07-2011, 01:22 PM
LVDell
LVDell's Avatar
So they had no washers on the plugs at all? Such half *** work some shops do. Another reason I do all this type of upkeep on the car. At least I know it is done right!
Old 08-07-2011, 01:58 PM
JG 996T
JG 996T's Avatar
Yeah, no washers on the turbo drain plugs. Total half-***.
There were washers on the crankcase plug and the oil tank plug.
While the change went smoothly other than the turbo plugs (not any different than any other oil change, but with more plugs), I had the iPad with Dell's write-up and my 996 companion handy - LOL.
Quick Reply: Oil Change DIY (pics)
