* 996TT REPLACEMENT discs - GiroDiscs. Comprehensive information & pictures*
#62
I just replaced the rears again and the fronts are still good, maybe half worn. If I trailered the car to the track I would put the same size Gyros all around and run the same pads on all corners.
This works fine for my track needs now.
Tytus
#63
So I have front set of Giro's need to replace the disc only, how many times can you swap disc from the hats before replacing the entire set (hat & rotors) I run PFC's 08 front and 01 rear - great balance and braking for the track little noisy on the street if you stop slowly Pm me $$ for front shipped to 33458 - thanks
#64
Former Vendor
I have several people who are on their 3rd ring set - the rotors last so long that the ultimate usage qty hasn't yet been seen by me :-) Check for hole concentricity (roundness)
#69
Hi Craig - Could I get cost for front & rear set for '04 996 TT, pls?
Tim
Tim
