OBDII Porsche specific fault code database request
Does anyone here have access to or have a list of the OBDII fault codes for the 996 Turbo? I have my own OBDII scanner, but the descriptions for the manufacturer specific codes ellude me (they start with P1,U1,B1, etc - as seen below in the chart). When I retrieved a P1114 code in my Turbo, I had specifics as to what it meant. It turns out that it was one of my main Oxygen sensors before the pre-cats. I had the correct code, but no database to reference it with. This site helps somewhat, but their database isn't complete: <a href="http://www.gendan.co.uk/diagnostic/dtcs.php" target="_blank">http://www.gendan.co.uk/diagnostic/dtcs.php</a>
Any help in getting the fault codes from Porsche would be greatly appreciated.
<img src="http://www.obdii.com/images/dtcdia.gif" alt=" - " />
For code P1114:
P1114 - Heating LSU, Inertia Fuel Shutoff - Signal Implausible
P1114
723 Heating LSU, Inertia Fuel Shutoff - Signal Implausible
Diagnosis conditions
Exhaust temperature above 250 °C
Battery positive voltage greater than 9.5 V
Time elapsed after start-up greater than 60 seconds
No faults of the oxygen sensor
Inertia fuel shutoff greater than 4 seconds
Possible fault cause:
Open circuit
Oxygen sensor
DME control module
Affected terminals
II/19
Diagnosis/Troubleshooting
<img src="http://boards.rennlist.com/upload/98722756.gif" alt=" - " />
P1114
Open circuit
Oxygen sensor
DME control module
Affected terminals
II/19
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by cobra06:
<strong>For code P1114:
P1114
Open circuit
Oxygen sensor
DME control module
Affected terminals
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Thank you. Where exactly did you get that info? I would assume that it comes from the Porsche shop manual(s)?
P1114
Open circuit
Oxygen sensor
DME control module
Affected terminals
